Question about Garden
Honda GX 160 quits running at variable times.
Honda GX 160 on a sprayer used for herbicide application. The engine starts fine when cold. Begins to sputter and the stop, may happen after 20 minutes of use or 2 hours of use. Will restart but quits right away until the engine is fully cool. Have gone through the fuel system with no apparent problems found. The oil level is fine. The first time this happened, the plug appeared fouled so cleaned but the problem persists. Is this eletrical, maybe coil or low oil sensor malfunctioning?
  • 850 Answers
A coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Posted on Jul 28, 2009
I have a Honda GX 630 that seems to run great but it has fuel in the oil when I change the oil it just keeps putting more fuel in the oil any explanation on why I could be doing this
It could be the type of usage and the duration of the runs are too short for the engine and the oil inside to reach normal working temperature. Lots of cold starts and short runs will inevitably cause some fuel contamination of the engine oil due to the relatively large quantity of fuel used during a cold start, much of which is not burned and some of which will find its way into the oil.
An hour of normal use would usually be enough to evaporate most of the surplus fuel from a small number of cold starts but some fuel residue will always remain, often leaving behind a fuel odour for those with a sensitive nose. This would be exaggerated if the oil pan capacity was quite small but the residue will do little harm over the short term in a quality oil.
It is possible there is a fuel problem, such as a small amount of fuel leaking past the carburettor float valve, which if there is no fuel tap and the system is gravity feed, some could find its way into the engine intake.
In this case cold starting would be possible without engaging the cold start enrichment and it might be noticed the oil level never seems to reduce or even begins to rise and fuel consumption would be noticed to be higher than normal.
If the engine is being used in a cold climate it is possible it is over-cooled and even when worked hard for long periods the oil doesn't reach a high enough temperature for it to do its job properly.
Mar 03, 2015 | Honda Cars & Trucks
When I run my Honda gx620 pressure cleaner/
Over heating, do you really need to run it for 3 hours in one shot???? Try one hour then let it cool down!!!
Feb 16, 2015 | VTwin Horizontal OHV Engine with Electric...
Gx
carburetor float is either bad or sticking.shut fuel off remove fuel bowl 10 mm bolt once removed pull pin out of float and inspect it at the same time re open fuel valve to allow fuel to push any debris the might be still in the port.re install float and test by slightly pushing the float upward and turn fuel on no fuel should drain unless you release the float if float has any fuel inside replace it if not finish putting it together and problem solved:)
Aug 22, 2014 | Honda 11 HP Engine w/electric start - GX...
Where to connect the throttle cable on a GX 31 honda motor FG 100 tiller
I look up honda engines at : honda-engines-eu.com they have the best access to detailed information. If you can identify the carb butterfly, any cable should attach to the butterfly control. I see a Honda GX100, but not a GX31.
Oct 09, 2012 | Honda Horizontal OHV Engine 340cc, GX...
Best spray tip nozzle for herbicide application, SOLO 425
tee jet yellow nozzle with metal inserts john deere/lesco sells them in packs of four these are best for 1 gal per k spot treating selective herbicide ......round up just use the adjustable cone
Jan 14, 2011 | Solo Backpack Sprayer
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Apr 11, 2010 | Chapin Spectracide Sprayer
Laking below sprayer large rubber piece covers area that is leaking
Sounds like your thermal relief has popped and is not reseting. These are an easy replacement. Usually availble as a "thermal relief valve" in sizes 3/8npt or 1/4"npt ..national pipe thread. Might also mean that your pump is overheating. Check and replace the pump oil. Make sure you do not allow this sprayer to sit and run without triggering the gun every couple of minutes.
May 01, 2009 | Garden
Honda GX will not start
you must check the connection wires on your fuel pump and check the ground wire too!!
Nov 01, 2008 | 2007 Honda Civic GX NGV Sedan
Sprayers support
It is recommended that gardeners have at least two sprayers, one for herbicide and one for pesticide. This is not a sales gimmick, the residue from many herbicides is difficult to completely remove form inside a sprayer tank. This leftover residue could potentially harm other areas if the sprayer is used there. Plus, it's not a good idea to mix pesticides. Make sure you label each sprayer appropriately.
Aug 27, 2008 | Aqua Cannon Adjustable Power Sprayer
Garden Logo
243 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
