Question about Samsung Washing Machines
Door won't open
A washing cycle has just finished and I tried to open the door of the Samsung washing machine. However, I was unable to and light on the display screen indicates that the lock in activated. I ran it through a drain cycle and tried again but faced the same problem.
    Scholar:
  • 106 Answers
Hi...
1) If you can get a small thin metal object in there and jiggle it around, you may get it open. If not, sheet metal panels will have to be removed to get to there. Do not smash the glass!!!
or
2) These door locks usually work with solenoids (Sp) if you unplug the machine (AND LEAVE IT UNPLUGGED). The door lock should release in no more than 10 minutes. there is also an emergency released built in somewhere, not being familiar with this model i will guess if you remove the front panel there might be a string you can pull to release it.
I think this solution will definitely help you...if yes then rate for my solution. Thank you for using fixya.
Posted on Jul 28, 2009
Red light will not go out so I cannot open the door
Generally machine take time approx 5 minit to open automatically open the door if not open please check door switch or pcb
Aug 07, 2016 | Washing Machines
Door stay locked after finished washing hotpoint w/machine ref 9526
See if you notice any water still inside the washing machine, if so run another spin cycle to try and remove it as it will not open if there is still water inside.
If you don't see any water inside, try unplugging it and letting it cool off, the lock should release after this
Jul 03, 2016 | Hotpoint Washing Machines
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
273 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
