Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Doesn't spray water and have checked all the recommended manual suggestions
    Problem Solver:
  • 9 Answers
Check the belts ( i would replace them even if they look good tho) if you have, and you still have the same problem the heater block is clogged you will need to take it into your local service center to have that problem fixed, i get 2-3 a week with the same problem. Good Luck!
Posted on Jul 28, 2009
Hoover floormate deluxe doesn't spray water
Fill tank with water.
Ensure the spray nozzle is not clogged from previous use. Refer to the manual for maintenance of the spray nozzle. Check YouTube for videos for this model. Contact Hoover website for support.
Aug 14, 2014 | Vacuums
Best way to clean a laminate "wood" floor. I use Pine Sol and lately have been noticing streak marks and dullness.
The old standby of glass cleaner should do the trick. Use a spray bottle, and spray a small 4x4 section at a time, let it sit for about 2min. , then wipe up with rags. Do NOT let it dry on the floor. You have a buildup of product on the floor. The pine cleaner has a small amount of oil in it and it builds up over time. For a good glass cleaner- I would suggest ZEP glass cleaner. For daily cleaning- I would suggest white vinegar 1 part vinegar to 3 parts HOT water. It will sanitize, and also remove salt stains from the floor left by winter boots and dog footprints.
May 19, 2017 | Vacuums
My Bissell pro heat 2x 9200 won't put out water HELP!!!
Hey Brenda! I can understand how frustrating it can be when you're ready to clean your carpets and no spray.
Here's a link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122&cid=ccsocial
Jan 15, 2013 | Vacuums
My Bissell proheat 2x cleaner will not spray the cleaning solution
- Check to see if the machine will spray through the hose with the setting on tools. If it does, the pump is fine. Continue troubleshooting.
- Check for debris on spray tips. Clean them with a soft brush (on old tooth brush works well). The spray tips may be lifted out for easier access.
- Ensure the tank lid is properly attached to the bottom of the tank. To attach this properly, remove the Water Tank from the machine. Hook the front window onto the lip of the bottom container and then allow the window with lid to cover the complete tank. Secure the latch on the back of the bottom tank to the back of the tank lid. THE TANK LID CANNOT BE ATTACHED PROPERLY IF THE BOTTOM TANK IS ALREADY INSTALLED IN THE MACHINE.
- Check the bottom of the Water Tank and the Formula Tank to make sure each has a red auto-load gasket attached. Make sure the Water Tank and the Formula Tank are seated properly. Depress the x on this gasket to ensure this depresses and release back out. Liquid from the tank should dispense.
- Remove the handle completely and re-attach. Once the handle is re-attached, re-attempt to spray.
If the machine continues to not spray, check the following:
REMOVE THE COLLECTION TANK:
• Make sure the unit is set to water rinse
• Remove the smart mix bottle and fill it with water only
• Place the smart mix bottle into the collection tank reservoir
• Run the unit and try to spray. If the machine sprays, you will be able to see the water level decreasing in the smart mix bottle and you will need to replace the bottom tank. It is possibly warped.
If your machine continues to not spray we would recommend having your machine inspected by a technician at a local BISSELL Authorized Service Center.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Apr 19, 2011 | Vacuums
Bissell will spray water when set to water rinse, but as soon as it is set to light, normal, or heavy cleaning, there is no spray. I have tried priming but to no avail. I put plain water in the solution...
Please check the following with liquid in both tanks.
If these suggestions do not resolve your issue, contact BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
For awhile my bissell quicksteamer works and then it dosen't It dosent spray water out.
Try the following suggestions to get your machine working properly.
- Please check the water level in the tank. It is imperative that the water level be at the full line when beginning your cleaning. Because this machine is gravity fed; if the water level drops too low, there will not be enough pressure to release the fluid.
- Please make sure that the siphon tube for the autoload insert (on the water tank) is perfectly aligned with the front and back of the tank. If the tube is turned to the right side or the left side of the tank the unit will not spray.
- Please check the vent hole on the tank. This hole is clearly marked and the water level must not be above this hole. The vent hole must also be clear.
- Please check the spray bar on your machine. The spray bar is removable so you may take this off if desired and inspect the spray holes to ensure that they are clear.
-Try removing and reinstalling the handle/screw assembly. The trigger mechanism is contained inside the handle. Occasionally it is possible for this part to become misaligned. To check for proper handle installation, try turning the handle from side to side and try to pull the metal part of the handle up or down....if properly installed neither of the previous actions should be possible.
Jun 17, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I have 2 bissell pro x2's that are now both not spraying water
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! d
Jul 22, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Eureka Atlantis 2590 Deep Steam Extractor will not spray
I cannot find a shampoo canister for my Eureka 2590 Series extractor. They are not made anymore.
Jun 07, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Bissell 7920-E; No spray.
I have a similar problem and `phoned Bissell support. They told me that no spray is either a failed drive belt or a failed pump. I suggest you remove the belt access cover and see if the belt is intact; if so rotate the pump using finger pressure - it should rotate easily with no unusual noises.
If this is all OK, fill the bucket and the mix bottle with warm, clean water. Turn the machine on and with the handle upright press and hold the trigger for about 2 minutes. Hopefully you should see a spray and both the bucket and bottle will reduce in volume. If not you have either a blockage in one of the tubes, the trigger valve needs adjustment or, worst case, the pump has failed.
Hope this helps.
Jun 06, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
No spray in hands-free mode.
Hi, I had the same problem ... I tried hot water for 30 minutes with no sucess ... then opened the unit and could see nothing real obvious in the solution hoses ... so took the main hose off the valve from the solution tank ... then plugged in the unit over a towel (be careful) ... and selected clean ... the valve opened and a bunch of fluid flushed through - so I knew the valve was ok. I then blew through the remaining hoses and did seem to get some flow .... and reassembeled the unit ... and filled the tank with vinegar solution ... the manual spray immediately cleared with a bunch of dark flakes ... the regular brush spray worked fine.
Sep 11, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
500 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
