Back to:
Tags:
Dishwashers
Generic problem for all Dishwashers
Green clean light flashing dishwasher (by 3 users)
posted by seigle on Nov 22, 2007
help me reset dishwasher so i cna use it caused by powere surge happened before and we wre able to reset
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by nothappy2008, posted on Jan 13, 2008
Have the same problem. Clean LED light flashes in sequences of 7 time. Can't start the washer. I tried the test cycle by pressing in sequence the Hi Temp, Air Dry, Hi Temp, Air Dry. After all the lights go on, nothing else happens. When is the test cycle over? I left it like that for 30 minutes and nothing changed. I finaly stopped it by pressing the Cancel key. I did that few times and still the clean LED flashes 7 times. I read the maintenance brochure behind the lower panel and it was little help. Any suggestion? Thank you
Comment by Guest, posted on Dec 08, 2007
I have the same problem with my diswhwasher, but there was no power surge that caused it, it just started blinking.
Of course, there is no informaiton in the manual to troubleshoot this problem.
Hitting the buttons did not help my problem.
Solution #1
posted on Apr 20, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
mine worked on sani rinse and heated dry. Thanks for the tips.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on green clean light flashing dishwasher:
I don't want to Accept this solution
Solution #2
Not Rated (0)
fmcwilli
Rating: 100%, 1 votes
I had the same problem with the flashing light I did run the diagnostice toggle and that allowed the dishwasher to run however it ran the rinse cycle repeatedly never really completing the cycle. 5 hours of running and it never stopped. Service tech came out check the thermistor and found no heat getting to the unit. Decided it was the controller board. This machine was brand new less than 10 washes on it. The board has been replaced and it now runs to spec.
Thank You!
Solution #3
posted on Dec 30, 2007
Not Rated (0)
jimmee
Rating: 100%, 2 votes
Mine worked on sani rinse and energy saver dry. Had a motor burn out that caused problem, and was really stressed when dishwasher wouldn't start after I put the new motor in. Thanks bunches!
Thank You!
Solution #4
posted on Nov 22, 2007
Not Rated (0)
chris72
Rank:Guru Guru
Rating: 93%, 396 votes
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode
Thank You!
Can you Help with these Dishwashers problems?
KitchenAid 24 in. KUDI02IRBS Stainless...
kudm01fkss1
Dishwashers
The on/off button does not work, and when it is on, it...
Beko 24 in. D3421F Free-standing Dishwasher
need a diagram to get to regulator
Whirlpool Gold 24 in. Built-In Dishwasher...
I have a older model moffat dishwasher. It still works...
Dishwashers
This is a dishwasher about 8 years old.  Model...
Loading problems.
Repair Service
Find Dishwasher Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
