NTLDR IS MISSING for HP 530
When i turn on my laptop msg cms.NTLDR IS MISSING for HP 530. I tried to reinstall windows XP but in vain. same msg is being displayed.
    President:
  • 627 Answers
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
    Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Posted on Jul 28, 2009
MSI U120. NTLDR is missing
Sounds like it's trying to boot off a CD in the drive that isn't bootable. If this is not the case, then you will have to reinstall the operating system. Here is a video on how to fix the problem if you have a second computer NTLDR is missing USB boot disk for Windows XP ntldrismissing com
Jun 21, 2014 | MSI U120-024US Notebook
NTLDR is missing press CTRL ALT DEL to restart.. How to fix wothout windows xp install or program disk
Try pressing F8 just before it tries to boot, you may be able to get into your system and back up your data. Then check out flea bay for a copy of XP.
Apr 09, 2014 | Dell Computers & Internet
Can't get N180 laptop to main screen.
factory reset with f11 at startup or try reinstall windows from recovery disks
Mar 06, 2014 | HP Compaq EVO N180 Notebook
Have a hp pavilion a705w that shut down one day and upon restart NTLDR is missing error came up and said hit alt clt del what do i do
Windows was writing to a file when the power went off. Now windows files are damaged. I'm assuming you have Windows XP on the machine. Do you have your Windows XP cd?
Mar 16, 2013 | HP Pavilion a705w PC Desktop
Ntldr is missing in HP 530
JUST REINSTALL YOUR OPERATING SYSTEM.
DONT FORGET TO VOTE.
Sep 14, 2009 | Computers & Internet
CANT BOOT FOR REINSTALLATION OF XP, IT SEZ "NTLDR" IS MISSING, ALSO MENTIONS SOMETHING ABOUT THE HARD DRIVE NOT WORKING
If you have the OS disks try a repair first. Run the OS disk and choose the repair option rather than reformatting. That usually fixes ntldr issues.
Apr 30, 2009 | Computers & Internet
About laptop starting
NTLDR is a system file of window xp .you have to repair your window with rhe help of window xp installation CD.
Apr 04, 2009 | HP Computers & Internet
NTLDR is missing
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
How to install xp on hp 530
You can try to change in bios show HD as ide native or something like that. If u install xp it gonna destroy your vista installation.
Jul 16, 2008 | Computers & Internet
Computers & Internet Logo
331 people viewed this question
David Payne
David Payne
