Question about Refrigerators
Ice maker stopped working on top freezer refrigerator ETIFHTXMQ01 Water flow seems to be fine since dispenser is working properly
  • 1 more comment
  • fjr0228 Jul 28, 2009
    I have the back of the refrig open and have removed the tubing whcih has green on left and red on right..I do not understand how to remove the valve..please explain further
    Thanks
    Fred
    i have been able to remove the valve successfully. Thank you.I ordered another valve from your website and hopefully when I install it the water and ice maker will work once again.
    I will accept the item as concluded once I install the replacement..
    Hopefully there is no other issue causing the problem
    Thank you for your help
    fred
  • fjr0228 Aug 03, 2009
    The solution was helpful. The ice maker is working now..The repair man gets an A for assistance and a tripple A for describing sow to remove the valve.
    Unofortunatley, I purchased another valve from your website. It arrived today and the icemaker is already working
    I hope to be able to return it for a refund
  • 15,935 Answers
The water flow from the water dispenser has no bearing on the icemaker.
The valve feeding the ice make and water dispenser has 2 seperate solenoids.
One is activated by the water dispenser switch - the other by the icemaker timer.
Your model number is ET1FHTXMQ01
Not ETI
See the valve HERE and is #16 in THIS diagram
To replace the valve:
Simply remove 5 or 6 self tapping screws to lower the cardboard backing with a 5/16 nut driver. Loosen two screws that hold the valve to the metal lip low on the back. Push 3 easy-connect fittings towards the valve while pulling the poly tube out at the same time. Replace the tubes by simply pushing into the fitting.
If you determine the solenoid is not getting the voltage required to open - the timer is defective.
SEE IT HERE
#35 in the diagram above.
Thanks for using fixya !!
Posted on Jul 28, 2009
  • 2 more comments
  • blueextc3221
    blueextc3221 Jul 28, 2009
    Push IN on the colored plastic while pulling OUT on the tubing.
    Much like a chinese finger trap or snake's teeth - there are barbs on the inside of the collar that grip into the tubing until/unless you push the plastic in toward the valve to release the teeth.
    Let me know if i can help further.
  • blueextc3221
    Oh - sorry i read that wrong... i thought you were having problems removing the tubing from the valve.
    There are simply 2 screws that hold the valve mount in place.
    Let me know if there is anything else.
  • blueextc3221
    I have indicated the location of the mounting screws with the red arrow.
    Hope this is more helpful.
  • blueextc3221
    Thanks :D
Water do not get cold it stay room temperture and stay warm.
Its faulty compressor if freezer section is also not cooling.
But if freezer section is working fine,then problem is confirm defrost assembly.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have a clear view ice maker and it fills fine and makes ice but it don't empty
Its issue with icemaker auger or dispenser assembly.Ice maker assembly has to be replaced.If any auger or auger motor is faulty.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
These will help.
Thanks,.
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
The freezer door is not sealing properly and seems to be off the track.
the spare seals are available,if the seals are not sealing,then may be its got worn out/ over stretched so it has to be replaced.
These will help.
Thanks,.
Dec 22, 2012 | LG LFX25971ST Bottom Freezer French Door...
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
These will help.
Thanks,.
Ice Dispenser on Kitchen Aid Model KSCS25FTBL has stopped working
It can be faulty ice maker assembly and needs to be replaced.
Sometimes it visually sees ok,but actually its worn out or cracked causing the problem.
repairclinic.com
partsselect.com
These will help.
Thanks,.
sadly you need to turn off the fridge let it dry out with the doors open then turn it back on.
Mar 31, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
