Question about Sharp AL 1631 Copier
SHARP AL-1644 H2 Error Code - Our usual maintenance Engineer has replaced the Fuser unit, but the H2 code is still flashing - Is anyone able to suggest the next step please? Thanks Adrian
  • 143 Answers
To enter the serviceman simulation mode, press the keys as follows:
Clear → Density select → Clear→ Density select
To cancel the simulation mode, press the clear key. Then enter code 14 then hit start.
Posted on Aug 01, 2009
I HAVE SHARP AL-1216,I DONT KNOW HOW TO REMOVE H2 ERROR CODE
H2 deals with the fixing unit.... You need to fix the problem before it can be rest. It may just be the fuser lamp is blown. You have to take it out and if it looks like a candy cane that is the problem. Good Luck
Jan 15, 2013 | Office Equipment & Supplies
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
SHARP AR163 Displaying H2 error code
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
My Sharp Printers Again
You are having a problem w/the fuser unit, w these units they usually replace the whole fuser, but check the themofuse or lamp.
Nov 04, 2008 | Sharp AR-M205 Copier
Sharp AL1644
The error code happens because the fusing temperature isn't getting to the right setting in time. No reset code is available for the fuser unit. It could be the thermistor that has gone bad with it but usually on this machine it's better to get the whole fuser assembly replaced.
Sep 05, 2008 | Sharp AL 1631 Copier
Sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
May 26, 2008 | Office Equipment & Supplies
Error code H2
That code indicates a bad fuser assembly. Replace fuser or have a tech do it.
Jun 19, 2007 | Sharp AR-160 Copier
Sharp AL 1631 Copier Logo
345 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
