Question about KitchenAid KESC307 Electric Kitchen Range
Kitchenaid gas oven
I have a kitchenaid gas stove and it keep asking me to set probe temp or turn it off and it wont let me turn it off. I dont want to use the probe temp function and I am not sure how and why it came on please help
  • 3 more comments
  • Anonymous Dec 29, 2007
    Yes, same problem and my oven won't work because of it. Mine is a gas range.
  • heliflier Jan 01, 2008
    Same problem...mine is an electric doble oven
  • mworthi3 Jan 16, 2008
    I have the same problem on a KitchenAid dual wall convection oven.  This must be a common problem; you can Google it all over the net.
  • KBobe67 Jan 22, 2008
    Same issue. I was able to bring up an error code by pressing Start and Off simultaneously:
    MOST RECENT CODE 0100 (Top line of display)
    AM71-0I73-EEKEO-068 (Third line)
    027-080 (Bottom line)
  • angelaboardm Dec 26, 2008
    Same thing. Happened after cooking a turkey using convection roasst, but did not use the probe. Any solutions???
Kitchenaid is the biggest piece of ****.
completely unresponsive to their faulty appliances
can someone start a class action ?
Posted on Oct 10, 2008
Does anyone know what the F7;EO means
Posted on Nov 18, 2009
  • 770 Answers
The Controller is asking you to set the probe temp because it thinks the probe is plugged in try to plug in your probe and remove it and see if it goes away if not the probe outlet is bad or if it flashes a code i will need to know that ..also you went into the Factory Version not the Error codes menu an error code would read like a F7 or F2 just an FYI
Posted on Jan 24, 2008
Our KitchenAid Electric Range display panel keeps indicating to set probe temp (and beeps every time) when probe is not even plugged in oven. When placing the probe in the oven jack it feels very loose. ...
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Aug 09, 2011 | KitchenAid KESC307 Electric Kitchen Range
Controls lost mind -- keeps asking for probe temp
Houston, we have a problem... Your electronic relay control, (ERC), is shot, kaput, no bueno and must be replaced in order to correct your situation. The ERC part number is 3191106, and retails for ~305.00 dollars! (I kid you not). I guess now is the time you might consider replacement over repair. That's a good question. If you choose to proceed with the repair, repost and I'll help with details on how to do it.
Aug 10, 2007 | KitchenAid KGST307 Gas Kitchen Range
Kitchen aid KGRA 806 PSS The " probe temp" words and icon feature on our Kitchenaide KGRA 806 PSS freestanding gas stove/oven will suddenly start to beep and flash.
This is a common issue and cannot be troubleshooted. The only way to fix this is to replace the temperature probe. The error will disappear and the range would start working fine.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting
Sep 28, 2010 | KitchenAid KERS807SSS Electric Kitchen...
Control panel not accepting commands
sounds as if the meat probe jack is shotring itself. thinks the probe is inserted, adn is lookin to continue on that course. aside form letting it stand and dry out , yo may need to either disconnect or replacethe meat probe jack
Mar 18, 2009 | KitchenAid KERA807P Electric Kitchen Range
Oven cooling fan keeps on spinning
Sounds like you have a oven probe or (if equipped) computer issue. From the looks of it, you dont have a computer on this model, so you probably have a thermostat stuck somewhere in there. The thermostat closes at the set temp, then opens when the unit cools. Sounds like this one is stuck in the closed position, allowing the fan to run all the time. You will have to look and see if you have a wiring diagram on the back of the unit, then find the fan wires and see which thermostat controls it. If no diagram, follow the wires out of the fan and see if on runs to a thermostat. Good luck and let me know if you need further info.
Nov 16, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Set probe temp or remove probe
my oven keeps telling me to input a temp probe and it keeps blinking and its getting on my nerves.
Jul 13, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchenaid Superba flat top range
we had the same code come up today; have you gotten a solution yet. we were not using the probe however the probe it was asking to set the probe temp.
Dec 23, 2007 | Kitchen Ranges
KitchenAid Gas Range Temperature Probe
We had the same problem, and we tricked it into running it's cycle be doing the following;
1. Wrap a wet paper towel around the probe, plug it in, and close the door. Then follow the temp. probe directions in the manual:
2. Set probe temp. at 130 degrees, then select a bake cycle. We selected convect bake.
3. Set oven temp for 275 degrees, but maybe any temp over the probe temp would work.
4. Then start. The cycle took 12 minutes to complete, and when it was finished, turn the oven off and then open the door and unplug the probe.
5. Now everything works fine.
Dec 10, 2007 | KitchenAid KGRC608LSS Gas Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
1,336 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
