Question about Whirlpool LER5636P Electric Dryer
Tumble Dryer overheating
My awz 129 whirlpool tumble dryer is overheating have changed the thermostst but this hasnt solved the problem.What is wrong and is it worth fixing
the dr
  • 447 Answers
SOURCE: dryer won't tumble
Check thermal fuse located behind rear panel mounted on dryer (depending on model of the dryer) duct. Fuse is the component with 2 blue wires and is white in color. Try jumping 2 wires together or OHM out fuse. Fuse being bad is a sign that either
a) Dryer vent is clogged ..... If dryer takes any longer than 1 60 min cycle to dry loads than the vent IS CLOGGED!!
b) Dryer thermostat (next to fuse with 4 wires 2lg red and 2sm)
is not cycling proper
c) some other electrical short causing element not to cycle proper
Check Temp of discharge air with thermometer
on High should cycle on somewhere around 120
and back off at no higher than 170 no less than 155
Posted on Jan 18, 2008
  • 55 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
http://www.whirlpool.co.uk/ifudocs/501930700361GB.pdf
Posted on Mar 25, 2008
  • 3 Answers
You can usually download from Whirlpool website
Posted on Jul 10, 2008
  • 45 Answers
SOURCE: I have a Whirlpool AWZ 7303 Condensing Tumble
Heating element is out.
Posted on Apr 28, 2010
SOURCE: have to replace broken belt on a whirlpool awz
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Posted on Sep 30, 2010
Whirlpool Tumbledryer AWZ-121/3 OVERHEATING PROBLEMS
When was the last you cleaned the hose leading off he back.
Pull the dryer out and remove the exhaust hose (probably held on with a hose clamp so you will need a flathead screwdriver.
Once it's off take the hose from a vacuum or shop ac and stuff it in there and get out everything you can. Do the same win exhaust hose, and from the front at the lint filter.
Jun 14, 2016 | Whirlpool Dryers
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Whirlpool dryer awz 121 only tumbles counter clockwise. This is a dryer that briefly reverses direction, so the only tumbling is when it reverses. The rest of the time, the dryer makes a noise but d
You may want to contact a professional that will have the diagrams for your machine online. there are some here or you can go to another site. like (Just answer.) Be more specific about your problem. It can be fixed . There's no worries.
Are you saying that it does not heat up either ?In addition with not tumbling clockwise ?
Disconnect the dryer first. You can remove the top and front of the dryer to check to see what is happening. If it does not heat . You may need to replace the temperature control relay. If that does not work , the heating elements themselves may need to be replaced.
For the tumbling problem, they also have relay switches that go out.
BUT, if it is tumbling to one side and keeps tumbling then that will probably be enough to dry your clothes. As long as it is not too heavily loaded.
Mar 19, 2014 | Whirlpool Dryers
Have to replace broken belt on a whirlpool awz 7813 tumble dryer and wondered what way the belt runs around tensioners
Sep 30, 2010 | Whirlpool Dryers
Whirlpool AWZ 8577 Tumble Dryer The water is not collecting in the top water container
You have a water pump in the base of the appliance this can sometimes fail or block. On the back of the dryer there should be a pipe just pull that off and blow down it, if there is a block this may well remove it. If not it's likely a pump failure.
Hope this helps
Mar 20, 2010 | Whirlpool Dryers
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
Jun 23, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
140 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
