Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Steering problem, wheels only turn about "half way" as normal. The teeth on the rack and pinion are jumping the teeth.
    Problem Solver:
  • 12 Answers
We need to know which model ride on you have.
Posted on Jul 28, 2009
Center a rack and pinion from under the dash
yes you possibly can ( depends on the room available.)
I would do the centring at the top of the rack and pinion as this is where a multi spline is that will allow for correct centring.
when you get the shaft off the box
firstly turn the rack from lock to lock ( wheels of the ground) and position the shaft at the midpoint of the turns counted fro left to right
next with the steering wheel place it in the straight ahead position
put the shaft back on the rack and tighten up the lock bolt
May 13, 2015 | 2003 Nissan Altima
Steering wheel turn all the way around no control
If your steering wheels turns all the way but your wheels don't:
This would have to be either a broken rack and pinion(steering gear) or the shaft between the rack and pinion and the steering wheel would have to be broken. This would need to be visually inspected to be sure which is the problem.
I would have to guess that your steering wheel is no longer connected to the rack (as opposed to something in the rack breaking). My best guess is that your steering column shaft snapped.
They can be replaced, and the necessary parts are sold, but it's not the easiest thing in the world to replace.
stick your head down under the dash on the driver's side where the brake and gas pedals are, and look up at the steering shaft (can't miss it). Now turn the steering wheel. Does that shaft turn?
Aug 26, 2014 | Cars & Trucks
My steering wheel turns but it doesn't turn the wheels on the car... I dropped my girl off at work and came home and as I was parking it stated to Lock up on me, when I finally parked, the steering wheel...
Sounds like something broke. Either in the steering column or the linkage between the column and the rack and pinion. Take it to a reliable repair shop for examination and repair. Best case scenario is the linkage between the column and rack and pinion came apart but I have never heard of it happening. Worse case scenario you need a new column or rack and pinion. You don't say what make and model of your vehicle is.
Jul 11, 2017 | Cars & Trucks
99 Olds alero will only turn to the right. On quick inspection found that the rack and pinion moves with turning the wheels. Is it supposed to?
The whole rack & pinion does NOT move! Only the rod out of either end of it. If the main body, where the hoses connect, is moving the mounting bolts are missing, or broken.
Normally any vehicle with rack & pinion steering, that will not turn left equals a bad rack & pinion.
The "wont turn left" is the classic industry wide indicator that the rack & pinion is worn out.
Aug 21, 2011 | 1999 Oldsmobile Alero
Pontiac G5. Steering wheel spins freely, wheels don't turn. Is this a U joint issue?
either the steering shaft has broke or the rack and pinion is broke have someone turn the wheel and look under hood near where the steering shaft meets the rack and pinion. do you see it spinning? if so the rack is most likely broke inside. if not the steering shaft may have snapped. hope this helps
Jan 31, 2011 | 2008 Pontiac G5
My 1999 Chevy Cavalier has difficulty turning. While I'm driving and about to make a turn, my steering wheel appears to only turn about half way making it hard to complete the turn until I violently yank...
the most probable cause is the rack and pinion steering system. check for leaks in system, make sure if its full of power steering fluid.. if all checks ok, then its in the rack and pinion. that causes binding. I had a car that did the samething on turns. it was the rack doing this.
Apr 08, 2010 | 1999 Chevrolet Cavalier
Power steering going bad,need info about rackard pinion
you can buy remanufactured at parts store or buy used from car-part.com. page with * is lowest cost.
It's a pretty big job for a novice.
here's 96 taurus steps with 3.8l engine. don't have 94. should be similar
Removal
SPECIAL SERVICE TOOL(S) REQUIRED Tool Number Description T94T-6000-AH Exhaust Connector Holder Tool T57L-500-B Bench Mounted Holding Fixture
  1. Disconnect negative battery cable.
  1. Position steering wheel one-half turn to right and lock wheel.
  1. Position steering column boot out of the way. Remove pinch bolt retaining steering column intermediate shaft coupling to power steering short rack and separate.
  1. Disconnect PCV vent tube and vacuum supply hose from clean air tube. Loosen two hose clamps retaining clean air tube and position out of the way.
  1. Disconnect power steering auxiliary actuator and power steering pressure switch.
  1. Remove two heat shield pushpin retainers from power steering hose bracket and remove heat shield.
  1. Remove one retaining bolt from left turn pressure hose bracket.
  1. Position drain pan under steering gear.
  1. Remove power steering pressure and return hoses from fittings on power steering rack. Position both hoses out of the way. Disconnect rear HO2S connector at steering rack and position out of the way.
  1. Partially raise vehicle.
  1. Remove front wheel and tire assemblies.
  1. Remove LH upper stabilizer bar link retaining nut and position link out of the way.
  1. Loosen LH tie-rod jam nut. Remove cotter pin and tie-rod retaining nut at lower control arm. Using tie-rod end separator or equivalent, remove tie-rod from control arm and from steering gear.
  1. Loosen RH tie-rod jam nut. Remove cotter pin and tie-rod retaining nut at lower control arm. Using tie-rod end separator or equivalent, remove tie-rod from control arm and from steering gear.
  1. Raise vehicle.
  1. Remove drain pan.
  1. Remove two steering gear retaining nuts at front subframe.
  1. Install Exhaust Connector Holder Tool T94T-6000-AH on flex tube.
  1. Remove bolts, nuts, and gasket from where flex tube and converter Y-pipe connect. Separate tube from pipe.
  1. Position Rotunda Power Train Lift 014-00765 or equivalent with wood blocks approximately 1016 mm (40 inches) in length (secured to lift) under subframe and raise.
  1. Remove two rear subframe retaining bolts and lower subframe approximately 102 mm (4 inches).
  1. Rotate power steering rack to clear bolts from subframe and remove assembly through LH wheel well.
  1. Remove two bolts retaining power steering hose bracket to short rack and remove bracket.
  1. Mount steering gear assembly in Bench Mounted Holding Fixture T57L-500-B.
  1. Remove four clamps retaining bellows to steering gear and tie-rods. Remove bellows and power steering gear rack tube.
  1. Position rack and pinion steering gear so several steering gear teeth are exposed. Hold steering gear with adjustable wrench on end teeth only, while loosening inner tie-rods. Remove tie-rods from steering rack. Remove steering rack from bench-mounted holding fixture.
Installation
  1. Mount new steering gear assembly in Bench Mounted Holding Fixture T57L-500-B.
  1. Position rack and pinion steering gear so several steering gear teeth are exposed. Hold steering gear with adjustable wrench on end teeth only, while tightening inner tie-rods. Tighten to 90-110 Nm (66-81 lb-ft).
  1. Apply Steering Gear Grease C3AZ-19518-A meeting Ford specification ESB-M1C119-A to groove in connecting rods where tie-rod bellows clamp to front wheel spindle tie-rod and uniformly apply to inner diameter of bellows. Install bellows and gear rack tube onto short rack.
  1. Install new inner and outer bellows clamps.
  1. Remove steering gear from Bench Mounted Holding Fixture and place on bench.
  1. Install power steering hose bracket and retaining bolts at top of steering gear. Tighten to 9-12 Nm (80-106 lb-in).
  1. Install steering gear retaining bolts in steering gear housing and install short rack through LH wheel well.
  1. Position steering rack and retaining bolts through subframe. Raise powertrain lift until rear subframe contacts body and install retaining bolts. Tighten to 135-195 Nm (100-144 lb-ft). Lower and remove powertrain lift from vehicle.
  1. Install power steering short rack-to-subframe nuts. Tighten to 97-132 Nm (72-97 lb-ft).
  1. Install new gasket, bolts and nuts at converter Y-pipe and flex tube. Tighten to 34-46 Nm (26-34 lb-ft).
  1. Remove flex tube holder.
  1. Partially lower vehicle.
  1. Install LH jam nut and outer tie-rod to inner tie-rod. Install tie-rod to steering knuckle. Install retaining nut. Tighten to 47-63 Nm (35-46 lb-ft). Install new cotter pin.
  1. Install LH stabilizer bar link and retaining nut. Tighten to 76.5-103.5 Nm (57-76 lb-ft).
  1. Install RH jam nut and outer tie-rod to inner tie-rod. Install tie-rod to steering knuckle. Install retaining nut. Tighten to 47-63 Nm (35-46 lb-ft). Install new cotter pin.
  1. Install tire and wheel assemblies. Tighten to 115-142 Nm (85-105 lb-ft).
  1. Lower vehicle.
  1. Remove old Teflon® O-rings from pressure and return hoses. Install new Teflon® O-rings on pressure and return hoses.
  1. Install power steering pressure hose and return hose to fittings on power steering short rack. Tighten to 33-41 Nm (24-30 lb-ft).
  1. Install one retaining bolt to left-turn pressure hose bracket. Tighten to 9-12 Nm (80-106 lb-in).
  1. Connect rear HO2S connectors, power steering auxiliary actuator, and power steering pressure switch electrical connectors.
  1. Position heat shield at power steering hose bracket and install pushpin retainers.
  1. Install clean air tube, connect PCV vent tube and vacuum supply hose, and tighten hose clamps. Tighten to 2-3 Nm (18-27 lb-in).
  1. Install steering column intermediate shaft coupling to power steering short rack and install pinch bolt. Tighten to 41-51 Nm (30-38 lb-ft). Position steering column boot over steering rack.
  1. Fill and purge system.
  1. Check operation.
  1. Adjust only toe for alignment. Refer to Section 04-00 .
Aug 05, 2009 | 1994 Ford Taurus
Steering wheel will not turn , when I turn the steering wheel to the right it make a poping sound but does not turn
you didnt mention whether it is manual or a rack and pinion..assumming its manual, check the gears were they mesh at the bottom of the steering column for proper operation. check for missing teeth, bad bearings ect..typically if it only does it in one direction, its most likely broken/missing teeth
Aug 02, 2009 | Poulan Garden
Problems with the steering
check if you got rack in pinion steering the mounting bolts for looseness .check tie rod end housing seats and the inner tie rod ball studs for wear.if all is good.your rack has worn pinion bushing and rack bushing.
Apr 10, 2009 | 1994 Mercury Cougar
How do i change inner tie rod , do i need a special tool.
i think steering gear has to be removed to get rubber bellows off to access tie rod.
486d579.gif Section 11-02: Steering System, Power 1997 Continental Workshop Manual
DISASSEMBLY AND ASSEMBLY Tie Rod and Bellows SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Bench Mounted Holding Fixture T57L-500-B
Disassembly
  1. NOTE: Drill out mounting holes in holding fixture with a 9/16 inch drill to allow the power rack and pinion steering gear assembly mounting bolts to fit.
    Mount power rack and pinion steering gear assembly in Bench Mounted Holding Fixture T57L-500-B.
  1. Remove tie rod ends (3A130).
  1. sve~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care not to damage bellows. If bellows are damaged, this will allow contamination into the steering gear and cause leakage.
    Remove four clamps retaining bellows to steering gear housing (3548) and front wheel spindle tie rods (3280). Discard clamps if damaged or excessively corroded.
  1. NOTE: Steering gear does not use rivets or roll pins between the inner front wheel spindle tie rod and rack.
    Remove bellows along with power steering gear rack tube (3K762).
  1. Position power rack and pinion steering gear so that several steering gear teeth are exposed. Hold steering gear sector shaft (3575) with an adjustable wrench on end teeth only while loosening ball joint nuts.
Assembly
  1. Expose several steering gear teeth and hold steering gear with adjustable wrench.
  1. Tighten each front wheel spindle tie rod separately to 90-110 Nm (67-81 lb-ft).
  1. Thoroughly clean steering gear and steering gear housing bore of any foreign material. Any abrasive material is extremely harmful to high-pressure oil seals.
  1. Apply Steering Gear Grease C3AZ-19578-A or equivalent meeting Ford specification ESW-M1C87-A to groove in front wheel spindle tie rod where tie rod bellows clamp to front wheel spindle tie rod and uniformly to inner diameter of tie rod bellows before installation. This allows for toe-in adjustment without twisting tie rod bellows.
  1. Install tie rod bellows and power steering gear rack tube. Make sure power steering gear rack tube is positioned as shown.
    Power Steering Gear Rack Tube and Tie Rod Bellows Installation
Apr 04, 2009 | 1997 Lincoln Continental
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
509 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
