Question about HP Pavilion dv6000 Motherboard
Display is intermittent
Dear FixYa Team,
Re: HP pavilion dv6000:
On boot the lights illuminate the keybrds media ctr /rom spins /hhd shows activitity but no display. The display however comes on intermittently after numerous restarts. Once in a blue moon I get to the desk top only to have the system freeze after bout 3 to 5 minutes.
Occassionally on the splash screen I get vertical red lines which leads me to believe it's graphical, but then I get to the desktop and no lines.
During the boot up, the system appears to be re-intializing, sort of cycling itself on /off, (indicated by lights dimming to off and then on again)
I have disable the following; all boot up programs, the rom, swap out memory chips and even remove the battery, Still the intermittitent & freezing displays continue.
All forums I check point back to the mobo, and as you can gather
it's out of warranty and HP support want me to pay for what clearly is an lemon of a product. I was either hoping for a full proof way to know if its the GPU or is it the MOBO....or even a solution.
Thanks for your time regarding this issue.
  • xalpha Jul 30, 2009
    Hello & thank you for your possible solution. After researching a bit on what you've explained it does seem that this maybe the problem, unfortunately to repair the problem is a bit out of expertise,( that is without making matters worst;). I will have a pro take a look at it.
    Thanks again, I will update you on the outcome.
the problem is with the nvidia gpu. the solder on the bga balls is unleaded and does not have the flex of leaded balls. the gpus needs to be heated on an ir solder station with preheater to 210 degree C for 30 seconds. this should cure it. if it still does not work, the gpu needs to be reballed. you can obtain replacement balled gpu from ebay. you do need to prep board correctly and use proper ir solder station to do this.
Posted on Jul 28, 2009
My HP Pavilion dv6000 screen goes dark when booting up.
Video card/drivers/wiring. Have it starting in safe mode. If the simptoms are similar, have it checked in service. You may need to replace video card.
Mar 06, 2013 | HP Pavilion dv6000z Notebook
Dv6000
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 30, 2012 | HP Pavilion dv6000z Notebook
HP Pavillion dv5-1113us laptop lcd screen backlight malfunction. My LCD screen is dark. There is no illuminated light to view browser, desktop, backgrond etc... Laptop boots up and runs but no screen...
I had same problem with HP DV6000. I ordered a new backlight on Ebay from Hong Kong cost $10 found a video on youtube on how to do it by typing in "replacing dv6000 backlight" apart from soldering a couple of wires was pretty straight forward and took less than an hour. Shop had quoted $400 to do this and fine is now working like new again. Good luck from Scott and please dont forget to vote
Jul 15, 2010 | HP Pavilion dv5-1113us 15.4" Widescreen...
I have an HP dv6000 laptop computer, and, starting last week, the laptop acts like it's turning on (all the lights illuminate, fan starts for a second) but nothing on the screen, and then the laptop turns...
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Dec 18, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp pavilion dv6000 laptop ...now displays no main page/screen only a blues screen is there an easy way to remove/fix this
This blue screen error comes when there is memory related issue.
For that first REFix your ram memory . It is in back side of laptop .
Then also you have to fix bugs on harddisk .
For that you need winxp bootable or recovery disk.
Then boot your computer with that disk.
You can set first boot device as your cd or dvd rom in bios when you power up the computer press F1 or
F2 or "del" key then ente rin bios then set first boot device as your cd or dvd rom.then save settings.
Then put bootablew disk in cd or dvd rom then follow the procedure then enter in recovery console mode.
Then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddisk.
Then if still face problem then choose your existing windows repair option .
Let me know if you need more assistanse.
Thanks.
Aug 30, 2009 | HP Pavilion dv6000z Notebook
Does not work, meaning does not read anything.
may be lens does not work and its life is end.or clearly tell me your problem what show this when you insert cd in cd rom
May 06, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Unable to install windows XP on my Notebook
you can't install Windows Xp from witin Windows vista. (not backwards comparable).
restart the computer press F12 when the HP logo comes up. that will bring you into BIOS. select advace>>boot order.
select CD-ROM as first boot. HHD asn second.
exit the BIOS and restart the laptop with CD in the CD drive.
press enter when the system start to install from CD......
and follow the screen (must reformat the HHD).
Jan 27, 2009 | HP Pavilion DV5234US Notebook Laptop
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv6000  Motherboard Logo
387 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
