Please try to clear the connector of the keyboard and fix it correctly, it may solve the problem.
Otherwise you need to replace the keyboard.
By the way, we supply all kinds of laptop part for the laptop www.laptopparteshop.com
Toshiba e205 keyboard,
Toshiba satellite l750 l755 battery,
Toshiba satellite l750 l755 black keyboard,
Toshiba satellite l750 l755 white keyboard,
Toshiba satellite l750 l755 cpu cooling fan,
Toshiba satellite l750 l755 laptop hinges,
Toshiba satellite l750 l755 lcd cable,
Toshiba satellite l650 l655 battery,
Toshiba satellite l650 l655 black keyboard,
Toshiba satellite l650 l655 white keyboard,
Toshiba satellite l650 l655 cpu cooling fan,
Toshiba satellite l650 l655 lcd cable,
Toshiba satellite c650 c655 battery,
Toshiba satellite c650 c655 black keyboard,
Toshiba satellite c650 c655 white keyboard,
Toshiba satellite c650 c655 cpu cooling fan,
Toshiba satellite c650 c655 laptop hinges,
Toshiba satellite c650 c655 lcd cable,
Toshiba satellite l670 l675 battery,
Toshiba satellite l670 l675 black keyboard,
Toshiba satellite l670 l675 white keyboard,
Toshiba satellite l670 l675 cpu cooling fan,
Toshiba satellite l670 l675 lcd cable,
Toshiba satellite c660 c670 battery,
Toshiba satellite c660 c670 black keyboard,
Toshiba satellite c660 c670 white keyboard,
Toshiba satellite c660 c670 cpu cooling fan,
Toshiba satellite c660 c670 laptop hinges,
Toshiba satellite c660 c670 lcd cable,
Toshiba satellite l660 black keyboard,
Toshiba satellite l660 white keyboard,
clear = clean, sure.
he meant, remove keyboard, per Oem manual
then see if ribbon cable fell off keyboard ends, even clean the ribbon end, if full of coffee. most noobs trying this break the keyboard connector, seen vast like that.
or the keyboard is dead.
or you upgraded (wrong way) the OS and now the keyboard driver is lost.
use device manager, look there first.
Press and hold fn and press f11.it sounds like you activated the sticky keys
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Spilled coffee on my keyboard and it no longer functions.
Its possible to open up the case and clean the inside but its a pain to do and you have to be very careful putting everything back. Personally I would view you coffee spill as an opportunity to use a nice new quality external keyboard. Using a new quality keyboard will be a much better experience.
11 years ago, he fixed it.
