Question about Intel Desktop Board D845GLLY Motherboard
My computer is switching on and nothing displays in the monitor. After switching on, after a minute it automatically switch off. Mother board is Intel 845 GVSR processor 2.4 GHz. Service centre person is saying that mother board is fried, and need to change the mother board or upgrade. Just tell me anyother idea, to fix this.
    President:
  • 627 Answers
Try a bios reset first.
Second pull out the memories (RAM). If you hear beeps on startup the the motherboard and the processor is ok.
If not, possibly could be the processor.
Also try with other power source.
Posted on Jul 28, 2009
    Problem Solver:
  • 15 Answers
Have you added any memory or hardware to your PC? If so disconect anything new and try to start it up again. DDR2 memory is fussy and needs to be installed properly if your useing DDR2 try booting up with one stick only in your machine. Also wile you have the case open make sure everything is pushed in properly. If its not that then I hate to say it but the service centre person could be right especially if the computer was working ok before.
  • 56 Answers
U have a wire from ur psu which is faulty for sure. i had d same problem. it could be either loose from d psu itself or from d motherboard. dis happened because d pc didnt have enouh power to run everything so it restarts to gain power
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
Intel 845 GL mother board no display ;processor memory & SMPS are working fine in another mother board
Does it have any beep sounds on switching on( some computers won't produce beep sound) or does your monitor is not getting any signals from computer even though it is ON and has shown any message or menu screen of Monitor functions then,
You will be having a faulty RAM or your Graphic port has some hardware malfunction.Or it can be also from a new unsupported hardware installation that will prevent computer from booting up.
If your monitor does not provide any of the above monitor functions successfully then
It would be a monitor problem. Check wires or cables of monitors or contact nearby technical support
Sep 06, 2010 | NEC Galileo 845GL (N4-IBFGL) Motherboard
D915GAG motherbord
cpu could be heating up or try anther video card make sure the mem is for that board
Mar 31, 2010 | Intel D915GAG Socket 775 Motherboard -...
No vedio
swap monitors if monitor is same dell brand then its the monitor. otherwise you can buy a Video card PROVIDED that you can disable from setup the MOBO video card, and install drivers, also speaking of drivers try uninstalling the video and monitor drivers first !! the do mon swap, finally new vid card .
funky things can happen to drivers, esp improper shutting down windows like flip a power switch or not having a UPS and computer shuts down during a power outage or storm. seen this happen as well.
Apr 26, 2009 | Intel D946GZIS Motherboard
No display on monitor
Check your RAM card and Video adapter .Because problem of one of that thing computer wont on the monitor video.
Jan 10, 2009 | Intel Desktop Board D845EPI Motherboard
Can't turn my compuer on
Check on *********** board that your CMOS jumper is in normal mode otherwise change it - also check any beep sound aswell as you remove all the cables ie.. IDE cables, front panel cables I mean only the 2 power cables to the motherboard and try to start the pc by shorting the power switch pin with a screwdriver see the display coming or not ????
IF it is a branded pc - you have to buy the same companies motherboard, normal motherboard will not work with branded pcs.
Sep 27, 2008 | Dell (S423) for Dimension 8100 (3F546)...
EMachine T3406 wont boot
is there a post beep when the pc is switched on. check the memory if it is a beep beep beep sound , also disconect the hard drive, dvd drive, floppy, and any usb devices and see if it boots up. if that fails it does seem like the mother board, also check the cpu fan has it stoped. also find out the power switch conector on the mother board, from the base unit switch to the mother board. also chech the power connector from the power supply to the mother board , on newer boards there are two that go to the mother board its self , a big one and a very small one .
Jul 05, 2008 | E-Machines eMachines Desktop PC
Intel Desktop Board D845GLLY Motherboard Logo
124 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
