SOURCE: I am looking for G.E Monogram parts.
here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
SOURCE: vegetable and meat draws freezing everything temp@16 deg. f.
Turn your thermostat down. If all the rest of the food was even 45 degrees, it would be okay. The vetable and meat drawers will always be colder, so you set the level for the rest of the fridge at what is tolerable.
SOURCE: GE gas stove top igniters won t stop clicking
I got this problem yesterday. My 6-month old GE range/stove top was being cleaned by a cleaning lady and suddenly, the igniters started clicking nonstop. I had to shut down the circuit breakers. I googled the problem, and it seemed clear that the "spark switches" got moisture on them. The best site which described this is: http://www.appliance411.com/archive/25012_ge_gas_cooktop_not_working_.shtml
Some people said you could dry them with a blow dryer, and others said you need to replace these switches (which is not too expensive, but takes some time/skill). I was hoping against this, so I tried something along those lines: I removed all the parts of the stovetop - the grill, the "cap", the metal funky piece, etc. until there was nothing but the surface of the stove and holes going down to the igniter area. Then, I took an electric fan and kept it pointed at the stovetop all night long. After about 10 hours, I turned the circuit breaker back on. No more clicking! And the burners all work! So, I think I essentially did the "hair dryer" solution, but did it more longterm without having to watch the clock to see if I did it long enough. Anyway, I don't normally post these things, but this discovery really helped me and I hope it helps someone else!
SOURCE: GE Monogram gas cooktop electric ignitor will not
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
