Question about Honeywell Heating & Cooling
My air condition unit stop cooling - Honeywell Heating & Cooling
  • 744 Answers
Hi..
Try turning the unit off for 24 hours and try again. It's possible that low voltage may be preventing the compressor from starting.
If no luck, the compressor should be checked to see if it's damaged. Also check any start/run capacitors and the controls in general...
thank u
rate me!!
Posted on Jul 28, 2009
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
Sep 30, 2012 | Heating & Cooling
My air conditioning unit just stopped blowing cold air today. It is a window unit, i'm not sure of the model number, but it is an LG.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Sep 22, 2011 | LG Heating & Cooling
Blown out warm air.
The problem is not solve. I am trying to locate a place where we can take the air condition unit to be repaired.
Thanks
Linda
Jun 19, 2009 | Maytag M6Y12F2A Air Conditioner
I have a a/c unit mitsubishi electric ms-12rv r22 when starting it on cooling or heating mode it stops after 30sec and the operating light flashes and the otdoor unit does not run the indoor unit fan stops...
Here is where you can find all the info you will ever need about Mitsubishi Air Conditioning units...
Check out this tip that I wrote about that...
Mitsubishi Air Conditioner Troubleshooting and Repair
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Apr 04, 2009 | Mitsubishi MS12TN Air Conditioner
Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
you probably have a defective contactor or start capacitor on condensing unit. if you pretty handy with wiring go to the condensing section open the panel. you should see a contactor (it's the little black piece with all the wires) check the condition of it. next to it is a capacitor and by the problem that you describe it could be that. check it if it looks bloated there's your problem just go an get an combination capacitor and wire up. (make sure the power to unit is off first. any other questions email me @ hvac.tech7872pr@gmail.com
May 09, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
