Question about Samtron 76df 17" CRT Monitor
My monitor colour has changed to yellowish
Suddenly one day my monitor colour has changed to yellowish but otherwise everything is okay what to do solve the problem pls help...?
    Sergeant:
  • 280 Answers
This could occur when one of your color guns is weak. Call a service person for a physical examination. A replacement of the gun should not cost you much.
Posted on Jul 28, 2009
    Problem Solver:
  • 6 Answers
The first thing to try is to make sure the video connections both at the monitor and the PC are secure. A number of color image problems are just a loose connection. Make sure you remove the connectors and then reseat them when you do this.
The color suddenly changed to where everything has a yellowish tint. And now the display is too wide to fit on the screen. How do I get it back to normal?
Right-click any free space on the desktop, choose properties, choose display, change the settings to 32-bit and which ever screen ratio you want.
Nov 20, 2009 | Proview PL926WBi 19" LCD Monitor
Red colour problem in compaq 7540
Check to see whether monitor terminal has a broken pin. Otherwise change the VGA card.
Sep 07, 2009 | Compaq CV 7500 17" CRT Monitor
Lg display yellowish
your vga cable has broken twist it if works otherwise you needs to replace vga cable
Aug 14, 2009 | LG Flatron F700B 17" CRT Monitor
Yellowish colour of the monitor
check the datad cable of monitor, if ok.then soldring may be dry ot the CRT neck
Jul 29, 2009 | Samsung 793S 17" CRT Monitor
The colour depth of my monitor is more yellowish.
is better check your vga cable which attached pc to monitor or change your monitor color on setting
bye
Jul 08, 2009 | Compaq CV 7500 17" CRT Monitor
Hi my monitors screen becomes yellowish.all colour effected y dis
Do you have a CRT monitor?
Have you tried to adjust the color on the monitor?
How is it connected to your computer?
It sound like one of the guns on you monitor died. But there is some testing you should do first.
If it is a CRT monitor and it is connect your computer properly. First thing to do would be to replace the cable and or try a different monitor that you know works.
To confirm try adjusting the color. If that does not work, if it more purplish it is the green gun, if it is orangish it is the Blue gun. That would be cause by a failed gun or driver.
If the gun is gone it is best to get a new one. It will save you money in the long run.
Thank you...
Jan 27, 2009 | Samsung 793S 17" CRT Monitor
Viewsonic E71f suddenly a change in colour as if a layer formed
there must be a loose contact between tracks of base on crt or may be dry solder remove it problem may be solved
Nov 21, 2008 | ViewSonic E70 17" CRT Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
I cannot ajust my screen the colours are awful
Check your vga driver is working ok otherwise run the vga driver setup ajust the resolution and refresh rate your monitor will be ok
If you monitor is red/blue or yellowish then you have to replace it because colour
Go to control panel then choose system - hardware - device manager - > expand the display adapter any exclamation mark or question mark there.
That means you have to reinstall its driver .
Thanks Hothawk
Jul 25, 2008 | Computers & Internet
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
Samtron 76df 17" CRT Monitor Logo
160 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
