Question about Nokia N72 Cellular Phone
How can I open my nokia n72 phone to insert a SIM card?
Just turn backside ur mobile you will see the small oval shaped button below .just press it with ur nails and pull downwards.urs back side panel opens .just simple
Posted on Jul 28, 2009
5 Suggested Answers
Acuraking
  • 42 Answers
SOURCE: nokia n72
I had a similar problem on 2 of my previous nokias. Usually if u take the sim card out and put it back in, and make sure it's all the way in then it's usually fine...at least for a while; but u should be able to call ur cell provider and talk to tech support explaining the issue and i think if you've had the phone less than a year it's still under manufacture warrenty and they'll do a phone exchange with u, sending u a new phone. Hope this helps, good luck.
Posted on Nov 06, 2008
fossildude
  • 832 Answers
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
Posted on Jun 15, 2009
  • 14 Answers
SOURCE: instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
Posted on May 05, 2009
  • 189 Answers
SOURCE: phone is restricted, need code to open the so that
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Posted on Nov 02, 2011
Hanging the phone n72 when insert sim card.
Your phone had a network ic i think it is the culprit here replace it with new one
Feb 18, 2012 | Nokia N72 Cellular Phone
Its show offline even if insert the sim
Try changing the sim card, as some sim cards may not work on other phones, or the sim card might be old.
Aug 26, 2011 | Nokia N72 Cellular Phone
Hi i have nokia n72 phone. its only working in offline, if i change the profile its showing insert sim card, so pls help me
Hi, kindly switch off the mobile and restart it, once you restart this will ask u phone is currently offlline mode u want to countniue, that time click no, phone will start.
May 31, 2011 | Nokia N72 Cellular Phone
For some reason my Nokia N72 shows that it is offline and when i try to set it to general or anyother mode it says insert sim card even though i got my sim card inserted....my sim card works perfectly on...
I think the best possible thing you must do is to get the software installed. It is too long a time to keep this fault on and cassue so much strain as it is possible to identify if the software corrrects the issue or else you have a fault in the harware section which must be estimated . possible chance of the SIM interface or the network IC being faulty.
Hope you try this out.
Aug 21, 2010 | Nokia N72 Cellular Phone
My Nokia N72 is working only in offline mode. I therefore cannot make or receive calls. When I try to switch to general mode, it says I must insert a sim card whereas the sim card is inserted. Will you...
This problem is called the 'insert sim' problem, there are several possibilities but first of all clean the sim card and the sim card interface on your phone. Next try it with another sim card. If this doesn't solve the problem, you need to go to the mobile repairing shop to get it serviced, or if you have idea in repairing mobile you can refer to this site on how to do jumper tips and tricks for this problem..http://sephonetechnology.blogspot.com/2009/08/nokia-n70-sim-ic-jumper.html Good luck.. and please...-:)
May 04, 2010 | Nokia N72 Cellular Phone
Hello my Nokia N72 Phone is showing Offline mode how to slow this problem
most probably its not detecting your simcard. but do this to confirm. switch it on with card inside, allow it to fully load. then click the power off button, shutdown options will appear. select general profile. at this stage, the phone will indicate properly if the card is being detected. if it says insert card, then check sim slot contacts and if problem persists, take to a nokia service point.
enjoy
Dec 03, 2009 | Nokia N72 Cellular Phone
I want to change sim card in my nokia N72
Dear
I think u have some problem with removing back cover of ur phone
To change sim card follow below instruction
1) Turn off your mobile phone (press switch off button on top of the phone)
2) Remove back cover by pressing unlock button on the cover & slide cover upwards gently (please take care you would not force the camera cover)
3) Remove Battery From the phone & u will see ur current sim or sim slot
4) Check instruction & insert your sim
Thanks
Mar 30, 2009 | Nokia N72 Cellular Phone
Insert Sim Card
1. its mainly due to Sim card get older and bend. So it cannot seat well in its slot.
2. Remove the Sim card. Check whether Sim card is normal. Due to the dust on the Sim also can cause this problem
3. May be the phone's Sim slot pin allignment problem. Check whether the all pins are good.
4. Some times when phone falls to the ground makes the Sim move from its slot. So also this problem occurs.
5. if problem persists even after these diagnosis methods.
6.Contact service centre for further Rectifcation. thank you
Dec 24, 2007 | Nokia N72 Cellular Phone
Nokia N72 Cellular Phone Logo
975 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
