Back to:
Tags:
Virtual Reality Sound Labs MP3 FM Modulator
Fuse installation for VRFM9 MP:3
posted by hogbody41 on Nov 22, 2007
Unit quit working and then realized that retainer ring holding fuse had come unscrewed. However, something appears to be missing as fuse is loose and falls out when I remove the unit from the cigarette lighter fixture. Is there some form of part that is supposed to hold the fuse intact inside the retainer ring? If so, where can I find a diagram of the specs and parts to identiy the piece I need and then order a replacement part?
Comment by hogbody41, posted on Nov 22, 2007
Went back to the car and searched the ash tray. Found a spring and a retainer cap with a lip on it to fit the plastic end that screws into the unit. Problem solved. Thanks for the effort.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Thanks for Trying (70)
LEE BRUCE
Rank:Guide Guide
Rating: 81%, 8 votes
there should be a spring to help hold the fuse in place,you might be able to get a replacement sring but you can get a new plug from a car place and then you can change the plug or you can take the plug apart and repair the you have..i know this will work as ive done this my self. please be careful when taking apart that you dont lose any thing in side the new plug..hope this helps.all the best..Lee Bruce.
Rating Locked! (?) hogbody41 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on fuse installation for VRFM9 MP:3:
I don't want to Accept this solution
Can you Help with these In Dash Receivers problems?
In Dash Receivers
I replaced my car battery last night. After replacing it,...
In Dash Receivers
I just installed an Alpine CDA-D852 into my 92 toyota...
In Dash Receivers
I have a cd player that will power on play for a short...
Unit quit working and realized that fuse was missing after...
Loading problems.
Repair Service
Find In Dash Receiver Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
