Question about Tomtom GO 510 Car GPS Receiver
I was updating my Go510 via the computer USB cable however, I discounted the cable before I "safely remove hardware" Now I have a blank screen and I can't turn off?
    Guru:
  • 1,894 Answers
This is not a problem. you may have removed the device before the data transfer was over.
i think you will have to reinstall the firmware to fix this
Posted on Jul 28, 2009
Just put of the power and put iet bak on it samtims happens n had dat problem two
Hi, I was trying to update the Nokia E71's software (300...). At the last second, Software Updater said USB is disconnected and asked me to try again. Actually USB was still connected. I removed...
the battery need not be removed . the problem might have been due to slight voltage fluctuation on line . The system should be flashed now via hardware reset , for which ull have to giv it to an authorized repair centre for sure . The flashing software and softwares to be installed and all cables are not available fr others.
Jun 05, 2011 | Nokia E71 Smartphone
Tip
Nokia N900 Firmware Update
Nokia N900 Smartphone Firmware Update v3.2010.02-8 (PR 1.1.1)
If your Nokia N900 smartphone is freezing, hanging or acting up I recommend you update the system software / firmware of your device. Erratic behavior can often be corrected by a firmware upgrade.
Here are the instructions for updating your N900 smartphone:
Over the Air (OTA) Update
  1. From the phone's home screen key in *#0000# or go to Device manager
  2. Select Options then Check for updates
  3. Follow the prompts on the screen to complete the update
Update via a Windows PC
  1. Download and install the Nokia Software Updater
  2. Connect your N900 to your PC with the supplied USB Cable
  3. Open the Nokia Software Updater application
  4. Follow the on-screen prompts to update your device
Update via a Mac
  1. Download the 770Flasher tool
  2. Download the latest available N900 firmware image
  3. Turn the N900 off
  4. Connect the N900 to your computer via USB cable (with the device turned off)
  5. Run the 770Flasher application
  6. Drag the firmware you downloaded in step 2 to the 770Flasher application (you will get an error regarding a USB device not being found, ignore it)
  7. Turn the phone on
  8. The update process will now begin automatically once the N900 boots
  9. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
Update via a Linux PC
  1. Download and extract the Linux Flasher tool
  4. Connect the phone to your computer via USB cable (with the device turned off)
  5. Open a Terminal window and run 'sudo ./flasher-3.5 -F -f -R' (you will get an error regarding a USB device not being found, ignore it)
  6. Turn the phone on
  7. The update process will now begin automatically once the N900 boots
  8. You are safe to disconnect your phone from the computer when you see the normal desktop reappear on the N900 display
I hope that helps.
on Apr 02, 2010 | Nokia N900 Smartphone
Music won't download it shows up on the computer but once it's unplugged from the computer it's no longer there...
Media players have certain folders for holding the data in the player.
Most players (not all) will accept 2 ways of files transfers and depends on the USB connection mode.
Some players switch automatically into the operating connection mode when connecting the USB cable.
Other players can be switched through specific key operation on the player or using the menu in the player.
Consult your manual or use internet support for information about your player's functions. See if you have to install software and maybe updates as well.
1. USB cable connect mode MSC = Mass Storage Class.
Using the explorer in "My Computer", seeing the player as an external flash drive:
When the files are not put into the correct destination folder, the content will not be kept in the memory of the player.
Before disconnecting in MSC mode always go through "safely remove hardware", the icon in the right corner of the computer screen: disconnect the player's flash drive in the icon "safely remove hardware", before pulling out the USB cable.
2. USB cable connect mode MTP = Media Transfer Protocol.
Using a software program like Windows Media Player 10 or 11, the player should be recognized as a media device:
Files must be put in a playlist on the computer first: create a playlist.
After that, synchronizing of the playlist onto the player has to be done.
When needing more help, just add a comment in this thread.
Mar 22, 2010 | Jensen Audio Players & Recorders
We have a tomtom GO510 and we called and the person said our software needs upgrading and she said there would be no charge for this
You need to go to the TomTom web site and register, then you can download the necessary software install that and THEN & only then connect up your GPS, with the USB cable, & turn on. Then you will be able to update it. Via the internet.
Feb 11, 2010 | Tomtom GO 510 GPS Receiver
There is an hourglass on the screen and the phone will not work.
Remove the back cover and remove and reseat the battery. Allow a few minutes for it to boot back to your main screen.
Then, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 14, 2010 | RIM BlackBerry 8700
Have blank screen, but remote works. Harmony 890
If the screen is still blank after you update the firmware in safe mode, then it is a hardware issue and you should contact Logitech's wonderful support team, given that the remote is still under warranty.
Hope that helps :)
Sep 25, 2009 | Logitech Harmony 890 LCD Remote Control
How can transfer phonestealth software from my pc (vista) to my motorola razor v3 via usb cable ?
  1. Plug one end of your USB cable to your phone then plug the other end to an open USB port on your computer.
  2. Step 2 Turn on your phone. Your computer will recognize the new hardware connected to your computer. It is safe to connect your phone to your computer when it is on.
  3. Step 3 Double-click "My Computer" on your desktop. Your phone will be listed on the new window ." . To copy files to your phone, highlight the file and drag it to the phone icon.
  4. Step 4 Double-click on your phone to open it and reveal any contents on it. Locate the files you want to transfer, then right click on each one individually. Scroll down the pop-up menu, then click "Copy." On your phone icon, right click an empty spot, then scroll down and click "Paste" to copy the file. Another way of transferring files is to drag them to the opened phone icon.
  5. Step 5 Click the "Safely Remove Hardware" button on the lower right of your computer screen. Highlight your phone on the hardware window. It will either be the (E:), (J:) (F:) or (D:). The message "USB mass storage device can now be safely removed," pops up. This allows you to safely disconnect your phone from the computer without damaging any files that have been transferred and saved to it.
  6. Step 6 Unplug your phone.
i hope this helps
Aug 15, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Cant connect to pc
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 07, 2008 | Samsung YP-U3 MP3 Player
I have no idea how it happened, but i plugged it into my computer to charge. and then i just saw my mp3 player and the screen froze and it says usb connecting and when i plugged it out it still said usb...
Nov 28, 2008 | Samsung YP-U3 MP3 Player
LCD Screen is blank
Had the same thing:
Step 1 - remove the battery for about 60 minutes. There seems to be a little energy store in the unit and just taking out the battery, counting to 10, and reinstalling it does not work.
Step 2- Do a software update upgrade from the Logitech site. The new firmware level seems to have fixed the base problem.
If you just take the battery out and put it in, it does not work.
If you take the battery out and just hook it up to do a software upgrade, it does not work becuase the remote gets power from the USB commenction so it remains "hung"
The most disturbing thing about the whole event for me was the number of people that had the problem occur about 12 months and 1 day after purchase....ie when it was out of warranty!!!
Oct 20, 2007 | Logitech Harmony 890 LCD Remote Control
Tomtom GO 510 Car GPS Receiver Logo
73 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
