Question about Car Audio & Video
I was looking for the hole cutout size for an old style speaker, Pioneer M165, do you know what that is?
    Sergeant:
    Champion:
  • 231 Answers
Go to crutchfield.com they have size chart for you particular car
Posted on Aug 05, 2009
I'm removing this Whirlpool oven and want to replace it with a KitchenAid Model KEBS109BSS. Will the new KitchenAid fit in the existing cutout?
Just fill in the old opening on the top with styling to meet the height needed. If the new one is narrower in width add equally to both side styles, if its wider trim equal amounts off both sides.
Nov 05, 2015 | Whirlpool Ovens
What size speakers do I get to fit a 1991 Nissan Patrol Ti?
Best way to measure it out so you dont make multiple trips is go to walmart in the parking lot take out one of each speaker. Its not that difficult to do just dont kill the wire. Bring them in make sure they know u brought them in and go look at the wall where they are on and stuff. Most walmarts have them. Measure it up like that because you need the holders to match up too unless you feel like making new holes fore some styles of speakers
May 08, 2014 | Kenwood Car Audio & Video
Opening size and cut out size, what do they mean? What's the difference?
The cutout size is the full size of the hole, before the hatch is installed. The opening size is the size of hole after the hatch has been installed.
Sep 10, 2013 | Building Materials
Is the pioneer TS-X200 good speakers?? Placing them in a old p/u truck.
It really depends are what your listening style. If you are looking for load speakers or a lot of clarity, these are not the speakers for you. These sound best at medium volume and music without alot of bass. The size of the speaker cannot reproduce low frequencies very well. Hope this helps.
Sep 05, 2011 | Pioneer TS-X200 Coaxial Car Speaker
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
VT Commodore 6x9 Speaker install
Hello taz_is_1,
Sure, it's OK as long as the new 6X9's are the same impedance as the door speakers.
Unless there are already wires and cutouts for rear shelf speakers, the installation will be pretty involved. And while I'm not sure of the Holden product, it's sister versions, Chevy Lumina and Omega, does not have such cutouts or wiring.
Wires going into the door interior for window controls, locks, and speakers will all be in a bundle and go from the vehicle frame into the door through a flexible rubber connector with grommets on both sides. You'll need to run your wires from the disconnected door speakers back through the same grommets to avoid pinching and damaging them. After you get them back into the vehicle interior, you can run them under the trim or carpet to the trunk area under the rear shelf. If you have never done such work before, I recommend you get someone who has to help you. You'll need to make an appropriately sized cutout to mount the 6X9's. And depending on the material, you may need some kind of reinforcement and/or spacers. Also, look out for anything underneath the trunk lid that may come into contact with the speakers. There's usually 2 metal rods than span the width of the trunk and run almost directly under the shelf. They will have to clear the speakers in order for the trunk to open and close properly.
It's more work than a simple speaker exchange with a good pair of aftermarket speakers. And the benefit is minimal. A really good set of 5 1/4, 6 1/2, or 6 3/4 Alpines, Bostons, or Infinitys will sound better than a mediocre set of 6X9's any day and you don't have to cut everything up to install them in most door openings.
Hope this helps.
Sep 07, 2009 | Pioneer tsa6970s 6 x 9 3W Speaker Car...
I Bought The Wrong Speaker Size!!!!
You have to cut out a large enough hole in your door to fit the speakers. But you have to keep in mind if your factory speaker came with a grill your new speaker will have to have one too. It will make it look better. As far as fit, you have to make sure the depth of the speakers are compatible with the window mechanism, or else you will have real problems when you go to roll down your window. Measure the depth of the stock speakers, and when they are removed, roll down your window to see if your new speaker will catch on anything. It may have the correct depth, but the diameter of the new speaker magnet/cage may be too large. If it fits, you are in luck. Get a handy saw/sheet metal cutters and make your hole big enough to fit. If you do not have enough room you will have to have a spacer added where your speakers will mount. A spacer on the outside of the door with the speakers mounted on top of it will work. Wood would be the cheapest route, using a solid piece and painted to match your color scheme. If you use the spacer, you may not have to cut on your door. If you want to get fancy, you can cover the wood in fiberglass cloth and resin to make some nice custom speaker mounts.
Nov 21, 2008 | 1996 Toyota Paseo
Pioneer Deh-3100 CD Player/Tuner Won't eject CD. CD spins around but can't hear it because suddenly and without warning none of the control buttons function. How to fix or remove.
This might be a shot in the dark, but there possibly is a reset. Look for a little hole, about the size of a paper clip, usually with the faceplate off. Take a straightened paper clip or reasonable facsimile and gently push into hole. If this works it will reset everything to factory and you'll lose your pre-sets etc.
Aug 13, 2008 | Pioneer Car Audio & Video
Pioneer ts w33c
Recommended volume for these speakers is 1-2 cu ft each speaker. Best materials are marine grade plywood and epoxy resin/matting. decide what space you think you can spare and see if you can make a box that will be about the right size in the space. always try and leave as much space behind the speaker as the speaker takes up from the front. look at the link below for some ideas of the ready made boxes you can buy. http://www.pioneerelectronics.com/pna/v3/pg/album/compare/0,,2076_310069931,00.html the speakers you have will need at least 2 one inch ports each in the back of the box, or equivalent. completely sealed can have bad effects on these speakers at high volume. I personally recommend keeping both subs in a seperate box completely, but a good solid box with a divider will probably work - make sure that no holes of any size exist between the two as this will cause distortion with certain channel set ups and is best avoided although some good results have been achieved with back flow between sub sets - it is a bit too hit and miss to be worth trying. If you need ideas how to fit these into your car so they look good - check out http://www.mtv.com/ontv/dyn/pimp_my_ride if you haven't seen it, check out a few episodes and you will get some great ideas and construction tips. Hope this helps :)
Mar 08, 2007 | Pioneer TS-W33C Car Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
