My dell lcd monitor is going crazy even is safe mode it scrolls on it's own, any suggestions
  • 53 Answers
I doubt if this is related to the software you installed.
Check the video lead that runs from the PC to the monitor.
Sometimes the insulation becomes damaged or the wires break.
With the computer on gently wiggle the lead around at one end or the other while watching the monitor, if the colour flickers then you have found the location of the fault.
Also check the plugs are in firmly.
Posted on Jul 28, 2009
How do you install the driver for a monitor if the monitor goes black
Go into safe mode and adjust the resolution of the screen to bare minimum. That usually allows most monitors to be usable at least inside normal operating mode.
Dec 07, 2011 | Dell E176FP 17" LCD Monitor
Dell E228WFP keeps entering powersave mode
disconnect all the cables from the back of the monitor except the power
you would see a test screen
if it still go to power safe while you are in the test page you monitor cud be bad better buy a new one as usually repairs are expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Dell Inspiron 1525 Laptop..the screen goes almost black after 5 minutes.
The screen goes black while in normal mode right? So try to boot in safe mode (power on then keep tapping F8 then select safe mode). Check if still happens in safe mode.
If screen does not goes black in safe mode it means there might be a software or driver causes problem when running in normal mode. You can try the following (update your anti virus software then run a full system scan, uninstall the video driver then download and install the latest one, uninstall any previous windows update or you can system restore to the time when it was working fine).
If the screen goes black even in safe mode they try connecting the laptop to an external monitor if still goes black, if yes then absolutely no issues with the LCD panel. You can try (uninstall and reinstall the video driver if still persist then this might end up replacing video card or motherboard, but before doing that update the BIOS first).
If does not goes black in ext monitor then the LCD panel might causes the problem. Reseat the LCD cable or inverter if you can.
Oct 22, 2009 | Dell Inspiron 1525 Laptop
We can not seem to get it to recognise our new hp pc.
Start the New PC in safe mode. In safe mode the PC will have low resolution, and must be seen in any monitor.
If you cannot see safe mode picture, then check the cables. If you can see picture in safe mode, go to Personalize in control panel, find printer settings and lower resolution and change screen size.
Oct 14, 2009 | Dell E176FP 17" LCD Monitor
Monitor stuck in standby
Try tapping F8 when booting and then choose 'safe mode with networking'
if this works go to the lcd manufactures web site and look for a specific driver for your screen.
Aug 30, 2009 | Dell E551 15" CRT Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
Monitor is black and is out of synch
go to bios setup then load optimal defaults settings thrn ssave and exit.
then when u power up the computer pres F8 key then enter in enble vga mode.
if u not able to get dispaly still u have to clear your bios settings.
open cpu plate then check on mother bord u see there cmos cell remove it for 15 minutes then refix it.
also clean ram and refix it.
Mar 23, 2009 | Dell UltraSharp 1905FP LCD Monitor
Monitor is in power safe mode
your resolution is set too high go into safe mode and turn the resolution to min and then play with it until it shows nothing push the space bar and leave the setting on that
Nov 18, 2008 | Dell E153FP 15" LCD Monitor
Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Jan 03, 2008 | Dell INSPIRON 6000 CENTRINO...
Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Jun 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
