Question about E-Machines (308714) Motherboard
I have a number of E machines they work great until the PS goes. Bestec is the name of the PS. Why does the PS always mess up the MB?
    Problem Solver:
  • 5 Answers
First of all, Bestec is a cheap power supply. When the power supply goes. the Bestec has no built in fail safe so it sends a power surge thru your MB. I would replace the power supplies before they fry.
Posted on Jul 28, 2009
No power supply power out, ps fan not coming on, fuse is good
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Dec 30, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
Computer has bestec atx-300-12e power supply. it
Actually no, the power does continually comes in but, when stopped, the PS is in a state that could be assimilated to stand-by - only a small side circuit is continually operational.
Jun 23, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
HP Mod a500n PC, flashing green ps light
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
May 20, 2009 | Bestec (ATX-250-12E) 250-Watt Power Supply
ATX Bestec 1956F Power Supply Failure
sounds like your power supplie has not been switched on by *********** board.the fan will not turn on until power supplie is turned on by mb.as far as what is wrong there are several things i can think of.i would try resetting bios. It sounds like your power supplie is working and your motherboard could have a short.but i have no way to be sure without testing. I can however tell you how to perform a test on your power supplie.unplug the 20 or 24 pin connector from your mb. look for a green wire,and then locate the grey one.short these two together(you can use a paper clip or something).if it dosnt power up. your power supplie is bad.also do not short any other wires,and only touch the grey and green for a few seconds as this is not how it was intended to be powered on.
Mar 03, 2009 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Power Supply Bestec ATX-250-12E Rev.P6
Normally if you open the PSU up warranty will be void. ( if it's Under Warranty). if not once you open the unit the fuse's are located right nest to the power input.
Jan 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Pc won't turn on
Hi, Are you able to test or repair some of this your self? is so use a multimeter and check the power supply,If you get no reading then remove the unit and open the cover, on the printed circut you will find a fuse either glass or ceramic. Replace this and also clean all dust from the unit replace the cover and reinstall in computer. If this fails you may need a new power supply unit. Regards mistyman
Sep 07, 2007 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
E-Machines (308714) Motherboard Logo
146 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
