SOURCE: how to lower the idle on a 2002 yamaha 650 v-star classic?
under the left side of the gas tank you will see i black knob/screw at the end of what looks like a hose. the knob faces the rear of bike. that adjusts the idle. its real easy to find and the only adjustment you can make to the carbs.
SOURCE: V-Star Tune Up
the stuff it came with is just fine. your bike shop where you buy the oil from will give you what they deem best for your bike, oil weights depend on where you are and ride. a K&N airfilter will help it breath better than the standard one but it wont do much for the performance. i have jardine pipes on mine i believe it was re-jetted when the previous owner installed them but i run a standard air cleaner and all is fine.
SOURCE: no spark from coils
i HAVE A 2006 V STAR 650 CLASSIC WITH A STARTING PROBLEM, COIL PACKS HAVE BEEN CHECKED OK, CDI IGNITION MODULE HAS BEEN REPLACED AND STILL NO FIRE TO PLUGS, KILL SWITCH ON HANDLE BARS BEEN REPLACED TOO, STARTER WILL TURN ENGINE BUT NO FIRE AT ALL
SOURCE: oil filter location
The filter is located on the right side casing near the front.
Can I get a “very helpful” rating on this answer?
SOURCE: where is oil filter located on 650 v-star yamaha
The oil filter is on the right side
under a cover with 3 screws in it.
Remove the covers and replace the filter
and the o-ring on the cover.
Watch which way it goes in
when removing it.
