Question about GE WSXH208A Front Load Washer
Hot water only front loader model wcvh6260fww
  • 86 Answers
It could be an open circuit coil on the cold inlet solonoid or a faulty diaphram in the solonoid.If you havn,t got a tester try changing the coils over from the hot to the cold.Hope this helps Cheers.
Posted on Jul 28, 2009
  • 850 Answers
Hot & cold hoses have a electric solenoide to control water flow [on or off] check to see if it is clicking [switching]
My wcvh6260fww front loader washer wont fill up with water
check the water valves then the screens in the hoses. if those are on and clean then the electric valves probably have burnt out and need replaced OR it is the DOOR LOCK has failed
Feb 18, 2017 | Washing Machines
My new LG front loader washing machine makes humming-buzzing noise when starting (only hot washing from 60C and above)
it is buzzing because it is try to let in hot water and is activating the hot water inlet valve/solenoid
Sep 06, 2015 | LG Washing Machines
No hot water cycle on ge wcvh6260fww
You need to replace the water inlet valve. Here is the part to order.
I have the complete service manual available if you should need it, post your email address.
Feb 17, 2013 | GE WCVH6260FWW
Is this model warm water by it self or need to connect with greaser?
If it is a front loader then it will heat it's own water but if it has both hot and cold hose connections it will require hot water for cycles over 50 degrees celcius. If it's a top loader then it will need a hot water supply.
Mar 11, 2012 | Washing Machines
My front load GE washer is filling with water and draining but doesnt spin, exept for the first two spins when started
it isnt the door lock or it would not work on the first 2 spin cycles and unless you have huge out of balance loads the door(not lid as lids are only on top loaders) interlock probably isn't at fault. i would cleanout the tub to pump trap inspect the pump for blockage and flush the discharge hose. it doesn't cost a penny to do this and has fixed many front loaders with the same problem
Sep 30, 2011 | GE WCVH6260FWW
My GE front load washer won't dispense water. Model # is WCVH6260FWW. I've checked the water hoses and the trap in front of my washer. When i turn it on it just turns and hums and locks the door like its...
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 04, 2011 | GE WSXH208A Front Load Washer
My Frigidaire GLTR1670A front loader hot and cold
sears parts direct carries a lot of parts can be accessed online can start there or just search for frigedaire part number
Dec 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Sep 20, 2009 | Bosch Classixx WFL 2066 Front Load Washer
I have a front loading GE wcvh6260fww that will fill with water, but will not agitate or spin out the water...thus, no washing of clothes regardless of cycle selected. The timer counts down and the water...
probably a bad door switch, if you can take the door or top off and find the wires running to the switch take the wires off theswitch and plug them together by wrapping electrical tape around them and then try the washer. If that dont work may be a bad control board
Sep 03, 2009 | GE WCVH6260FWW
GE WSXH208A Front Load Washer Logo
75 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
