Question about Stanley Bostitch Coil Framing Nailer
Firing Pin doesn't return
I'm working on a Bostich N63CP Coil Nailer. I took it apart to find the firing pin guide shattered so I replaced. However, the tool still doesn't work. The pin fires but then will not return. It can be pushed back into place w/ an allen key. Seems as if there is no air pressure to return the pin. How do I fix this?
  • 154 Answers
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Posted on Aug 05, 2009
Nbosb bostich nail gun air is leaking out trigger how to fix?
I am not familiar with that model number, however if your nailer has a round plastic trigger valve, it should be easy to replace. Most bostitch nailers use a TVA6 valve that sells for about $20.00. Better to replace the valve because, if plastic, the firing pin in the valve becomes very worn/loose over time and orings will not work. Easy to check. Remove the trigger and try moving the firing pin from side to side. If it moves, replace the valve. If your gun has a metal threaded-in valve, remove the valve and replace the orings with generic. Usually 2mm on the pin and 5mm on the inner spool. Local bearing company can measure them for you. Good luck.
Aug 09, 2014 | Air Tools & Compressors
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
Striking pin does not return to firing position
Bad 0-ring or bent firing pin...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 20, 2010 | RTO PasLode 900420 Impulse Framing Nailer
My bostitch n63cp coil framing nailer blows air continuously near the trigger and does not shoot the nail. What is wrong and how can I fix it?
Replace the trigger valve assembly. Part TVA6. It takes just a few minutes. The part will include a pin punchout tool, you supply the hammer.
Jun 28, 2010 | Stanley Bostitch Coil Framing Nailer
Brad nailer pin won't retract all the way back after firing tried oil and took apart and cleaned
Make sure that you use a water soluable oil made for air tools--never engine oil. Make sure that a piece of brad has not been lodged behind the nailer pin or that the head of the nailer pin is not 'mushroomed'. Check the condition of the 'return' spring that it is not crushed, warped, or broken. Check the condition of the piston 'O' ring.
Nov 20, 2009 | Cars & Trucks
DeWalt Frame Nailer 51844 extends firing pin when air hose attach
Check whether the trigger is working properly, and whether the air valve is not leaking.
Jun 13, 2009 | Dewalt Round Head Framing Nailer D51845
Paslode framing nailer when fired pin stays out wont retract
Check the anvil guide for damage first (ie: burrs, nicks, etc.) Then go to the chamber for the return spring. That is where your problems are.
May 12, 2009 | Craftsman Nailer Kit, Palm Air Driver
Not firing
May need cleaned and lubed. Check for bad o-ring.
Mar 19, 2009 | Stanley Pneu Roof Stapler
Bostich N80 Framing nailer
Sorry about the delayed response. This unit needs to have the O-rings replaced. The return of the firing pin is not happening correctly. This means that the pressure release holes are still engaged. When the pin pushes out the nail, the return should cause the holes to get covered. If there is an air leak, the return will not complete resulting in an even larger air leak which is what you are now seeing. This is a relatively simple repair for any shop that handles these and would be considered a standard maintenance effort. These are decent tools and with proper maintenance will last for years. Mine is over 22years old and going string.
Dan
Jan 26, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Stanley Bostitch Coil Framing Nailer Logo
516 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
