Question about Video Cameras
CAMERA DOOR CAN NOT OPEN AND THE LIGHT FLASHES RED. THE MOTOR RUNS BUT THE DOOR DOES NOT OPEN.
    Guru:
  • 1,894 Answers
Please hit the camera gently and see what happens. sometime the door gets stuck due to some dust particles or due to manual pressure prevention from opening the door. see if you get any error in screen
Posted on Jul 28, 2009
B&d control a door mpc2 model not opening control panel has flashing green up down light and also flashing red light limit set
Check your user guide if available. It sounds like you haven't set the door open limit, so press the up arrow & fully open to the door & push set, do the same for the down arrow until door is completely closed. Push the set button again & the door should be right..
Apr 19, 2016 | Building Materials
The opener won't close. My husband said the sensors need to be realigned. Did that and still the opener halts after 2 inches and flashes the light? It is a six year old Sears Craftsman Chamberlain model?...
If the main light flashes 10 times it is a door sensor problem. If the main light does not flash then you can try increasing the down force. This is a control on the rear of the motor unit near where all those white wires go. If this doesn't help you probably have a bad infra red sensor board. This is a small printed circuit board just in front of the motor.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman garage door opener model 139.53325SRT 1/3 HP, it was working fine and then it would not open, when push the wall switch, the opener hums and the light starts flashing, I have removed the...
It sounds like your door sensors may be misaligned. If when you try to close the door the main light flashes 10 times and the door reverses to the open position this is the case. Make sure the small light on each sensor is lit and not flickering. Tweak the sensors to see if you can get both lights to come on. If not you have a bad sensor.
Feb 24, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a liftmaster professional series 1/2 hp garage door opener that is about 10 years old. When I press the button to open it (or even to turn on the light) there is a clicking sound but nothing...
That is the code for "RPM sensor or motor overload". If the door is stuck open and the trolley is jammed against the bolt just in front of the motor unit it will cause this problem. You can remove the bolt and then run the opener until the door closes. Then locate the 'up limit' control on the side of the motor unit and turn it 2 turns in the opposite direction of the arrow printed on the cover. The RPM sensor board is a small printed circuit board just in front of the motor.
Oct 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Motor humms but door doesn't go up or down!
5 flashes is the code for "RPM sensor board or motor overload." If your door is stuck in the open position the trolley may be jammed against a bolt just in front of the motor unit. Remove the bolt and run the opener until the door is closed. Now locate the 'up limit' control on the side of the motor unit and turn it a couple turns in the opposite direction of the arrow printed on the cover. Be sure to replace the bolt.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open
The light flashing 5 times is the code for RPM sensor or motor overload. The RPM sensor is a small printed circuit board just in front of the motor. I would really doubt it is a motor problem unless you have been operating the opener enough that the thermal overload protector has shut it down. It will start running again as soon as it's cooled off.
May 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not open
try pulling emergency rope open door and close it this may reset opener if you have electric eyes make sure they are clear and they line up
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Nov 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Video Cameras Logo
117 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
