Question about Motorola Mobility MOTO ZN200 Cell Phone
How can i delete application from phone memory
  • sai1973kp538 Jul 28, 2009
    Motorola ZN200
  • Prasanth Prabhakar
    Prasanth Prabhakar May 11, 2010
    Could you Plz tell me the make of the Phone
I'm having this problem in my nokia e5 : My memory
If the phone notifies you if the phone memory is getting low. To free phone memory you have the following options:
  • Move data that you want to keep to an alternative memory (mass memory or memory card, if available) or to a compatible computer.
  • Remove data you no longer need.
Use File Manager or the respective application in your phone to remove data or to move data to alternative memory as described in the user guide. Typically you first mark files to be removed or moved and then you select the corresponding option (Delete orMove to folder).
Use Nokia Ovi Suite to move data to a compatible computer.
In order to free phone memory, you could remove or move the following:
  • Messages from Inbox, Drafts and Sent folders in Messaging
  • Retrieved e-mail messages from the phone memory
  • Saved Web pages. Clear the web browser cache to free some phone memory (e.g. select Options > Clear privacy data >Cache).
  • Saved images, videos, or sound files (in Gallery, Photos,Videos or Music player)
  • Contact information (in Contacts)
  • Calendar notes (in Calendar)
  • Downloaded application packages
  • If there are applications which are not needed any more, uninstall them with Application Manager
  • Any other data that you no longer need
If you are deleting multiple items and any of the following notes are shown: Not enough memory to perform operation. Delete some data first or Memory low. Delete some data, try deleting items one by one (starting from the smallest item). After deleting data, restart (power off/on) your phone.
Tips: Use the memory card or mass memory instead of phone memory in the Camera or other applicable applications in case the selection is available (e.g. via Options > Settings >Memory in use).
I hope this helps!!
Aug 06, 2017 | Cell Phones
Phone keeps showing "C Phone memory full delete
phone memory should always be free... its the ram for your phone... you shoul keep all your files , applications and messages in memorycard ..... if memory in phone is low it will work slowly and you will not be able to open large sized applications in your phone
Oct 11, 2011 | Nokia N73 Cellular Phone
I bought nokia c5 , and i don't know how to delete some applications as the message of memory full delete some applications is usually appearing please help me
To delete the application on the phone is quite simple.What you need to do is to go to the main menu, then you select application, then you select the application you want to delete,then you select option and scroll to delete, then the application will be deleted.
But i will suggest you move the applications instead of deleting them. To move the applications, just do the same thing you did when you wanted to get to the application to delete, then you select move instead of delete, it will ask for where you want to move the applications to, then you select the memory cards position, then the applications will be moved to the memory card.
Thank you for using fixya.
Caseytech
Sep 05, 2011 | Nokia C5 Cell Phone
I have a nokia c5-03 and i get the message:not enough memory to perform operation.delete some data first but i cannot enter anywhere(in settings) or application manager,etc because i get this error. also...
I hope this helps!!
Aug 06, 2017 | Nokia Cell Phones
My phone dont let me get pics or music its says that tha memory is full i check why and its says that there is applications consuming the hole memory of the phone but i cant and dont know how toresolve...
there are certain ways to delete the application that's eating up your memory depending on the brand of celphone that you have. however if you just kind of choose and delete carelessly, you might delete something that may affect your phone and break it instantly.
here are the steps:
1. Go to the main screen
2. Select Options
3. Select Applications
4. Select the app you want to remove
5. Select Delete from the menu
6. Confirm deletion.
May 19, 2011 | Cell Phones
When i try opening my applications and games it says "resource not available" and when i try opening my facebook it says "maximum amount of applications reached when i've got nothing open
where did you save your applications? you may have saved it on your memory card, if the applications are saved on your memory card, the files may have been deleted or corrupted. or if the applications are saved on your phone memory, then it may have been deleted or corrupted.
regarding your second inquiry, you may not have enough memory left, try to delete some apps, try to turn off and on your phone, remove battery and sim card. wait for a few seconds before you turn it on. then try to access some applications.
Apr 14, 2011 | LG GT350 Cell Phone
Hi, My N73 shows Memory full & ask to delete some data, except the phone book i have deleted all the other data, but still the problem persist, i am not able to send or receive mgs's nor view the...
Its mean phone memory is full, you can make some space by deleting some installed application. Delete also all cache/history in your browser. If the problem persist, reset your phone to factory setting after put off your memory card. After resetting the phone, your phone memory will be empty again and you can reinstall your previous application. Avoid to install application in phone memory (always install in memory card).
Hope this help.
Feb 25, 2011 | Nokia N73 Cellular Phone
My nokia N73 sHow is memory full status what will I do?
Hi, You can delete your old messages both (inbox and outbox messages) the also go to your call log menu, to delete all your old calling info. be it miss call, dial call or received call. This should be able to free the memory of the phone. Also try to remove or delete those applications that you think you don't always use or delete some of your newly installed application to free your phone memory.
and if you think all this have benefit for you, then get a higher bytes memory card for your phone.
Jul 05, 2010 | Nokia N73 Cellular Phone
Motorola Mobility MOTO ZN200 Cell Phone Logo
44 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
