Question about Microsoft Xbox 360 Console
Disc drive wont open or close
Oh the joys of children, my 2 yr old got hold of the disc drive unit and wrenched it out it is now stuck half way in/out, and won't budge, any ideas in how to dismantle one of these or should i just send it off for repair ??
  • no1bert Aug 03, 2009
    cheers for that, unfortunatly its over 3 yrs old and warranty was lost ages ago, think its a trip to PC World !!
  • 51 Answers
This problem might not be covered by the warranty so if you want to send it in it might cost some money (call them first just to see how much). If you attempt to repair it yourself it will void the warranty (they wont repair a voided console at all), there are guides on the internet to help you take apart your system and repair it but it takes some experience. Call support first!
Posted on Jul 28, 2009
  • crispy_ninja Aug 03, 2009
    All right then, self repair it is. Just replace the DVD drive and you should be fine, but make sure the drive matches the motherboard.
How do I get the disc drive of a dvd recorder to open after getting out the disc and resetting the machine?
Go back through the release process you did the first time to remove the stuck disk. it appears that part of the mechanism that moves the drive did not engage again.
Apr 25, 2015 | Panasonic Televison & Video
Dvd door will not open
with the unit turned off press and hold "8", and then press "x" on the unit until "unlocked" appears on the screen.
This is from page 83 of the manual regarding tray lock feature.
Nov 18, 2007 | Televison & Video
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
Something stuck inside disc drive
try this, press and hold eject button for around 15 seconds, this resets the cd drive, hope this helps
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Something stuck in disc drive of ps3
There is no need to open up the console! Make sure the power is off! Get someone to hold the PS32_bing.gif upside down (so the disc slot is facing down) then get 2 butter knives insert them carefully one on the left and one on the right of the disc slot. Now gently push the knives away from eachother so that the one on left goes left and the one on the right goes right. You will feel them push the brackets that hold the disc in. As you push the brackets you will release the mechanism that holds the disc in and it should just drop out. I did this with mine when my little boy decided to put a credit like card in it!
Disc wont eject
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
Jan 01, 2009 | Panasonic SC-PT960 Theater System with...
Co.clare eurovox chorus channels gone
The "Unplayable Disc" error has also been heavily reported. The error appears to be limited to the Hitachi CD/DVD ROM drives that replaced the earlier Toshiba drives. The error message is preceded by a loud series of grinding noises and the system returning to the dashboard. From that point forward, any disc that is put in the unit will result in the "Unplayable Disc" error (although if the user was to eject and close the disc tray in quick succession the disc may sometimes play).
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
Govideo r6750 stuck tray
my 10 year old nephew forgot to take a disc out and inserted another this stopped the tray from opening i had to undo the screws holding the cover and remove them .Good luck p.s. don't forget to unplug firse
May 21, 2008 | GoVideo VR3845 DVD Recorder/VCR
DVD Tray won't stay closed
It can only be repaired by the repair shop I think your son broke a lug on the inside it may need a new tray?
Sep 13, 2007 | Zenith DVD5201 Multi-disc DVD Player
Camera wont take a disc
hi NanaR, i suggest a try with new disc,problem still remain, i think there is a mechanical problem with disc holder. I suppose you have the facility to use memory stick so why you use the disc just use the memory stick. It is better for you. to fix the problem you have to go to sony shop.. good luck...
Jul 28, 2006 | Sony Mavica MVC-FD75 Digital Camera
Microsoft Xbox 360 Console Logo
119 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
