The drum is stuck - it will not move
Indesit Top-load washing machine. The drum is stuck in upside down position and won't turn or move by force. The clothing is inside. The washing machine goes through a cycle - fills water and drains water - but the drum doesn't turn. It doesn't spin either. The engine makes the usual noises - but the drum is stuck?
  • 2 more comments
  • ngraae Jul 28, 2009
    I did inspect it visually after disconnecting water and electricity, but the bearings are on each side of the sealed plastic unit with the drum - and they both seem to be fine. There's no belt from the engine as the engine seems to be connected directly to the sealed unit.
  • ngraae Aug 01, 2009
    Well - I got wiser. I hadn't removed the other side of the washing machine where the motor and Belt is. yes - there's a belt and it had snapped - probably while attempting to spin because the drum was stuck.
    The drum moves maybe 0,5-1 cm either direction until it hits something and a clanking/scraping noise is heard from the bottom of the washing machine. it sounds like the closing mechanism of this top-loading washing machine is somehow stuck at the bottom of the sealed plastic unit the drum is inside. At the bottom is the outlet for the washing water. Maybe the opening/closing mechanism has failed and it has opened and got stuck in an upside-down position? When looking through the top cover of the washing machine it appears as if i'm looking at the bottom of the drum.
    Hmm. The belt is completely off. it partially melted in one place and snapped. the flywheel and engine are completely exposed - there doesn't seem to be any other parts of the belt there.
    How does one remove the drum? The drum is located within a plastic unit which appears to have been closed by a series of plastic rivets all around on both sides of the drum.
  • 850 Answers
Overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
  • 1 more comment
  • ROB Jul 28, 2009
    if it wont move the you may have seized a bearing
  • ROB Aug 01, 2009
    you may still have a piece of the belt ot something else jamming the brake mechanism !
    drum will need removing for further investigation
  • ROB Aug 01, 2009
    sorry but it will need a specialist to mrepair it from this point!
    good luck
    Cheers Rob
I had an issue with my Electrolux top loading washing machine where the drum got stuck with the drum dor facing the bottom and manged to fix it as follows: Opening the side panel of the washing machine showed that the belt fell off as well.
The heater element in this machine is located on the bottom side of the drum casing just above the engine. I have removed the wires connected to the element, unscrewed the nut holding the element in place and removed it. From this I got access to the inside of the drum casing and could close the lid in order to turn the drum up again. Seems like this happened due too putting too much clothes in the machine so the door got opened when it reached the bottom position and got stuck on the heating element.
Posted on Jan 22, 2014
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
How do i change a belt on a indesit washer machine its a wd 12
Usually there is a back panel that can be removed to give access to the motor and pulley wheel for the drum. If not then remove the top panel and look down the back and you will see the big drum wheel. you will also be able to see the spindle for the motor at the bottom. Reach down to the motor and hook the belt around the spindle and place as much of it as possible on the pulley then turn the wheel to pull the rest of the belt on. It can be a little tricky but the only other way is to completely remove the back half of the machine. If you get stuck try www.espares.co.uk and check the advice centre, it gives a video on how to change a belt, most machines are similar. Hope this helps.
Mar 02, 2011 | Indesit WA 115 Front Load Washer
Washing machine is making noise even when drum isn't moving. Constant noise as if something is stuck inside.
hello,
the problem is from the jet stream that is the(rotor) which generate force on the drum to move on to is position it means that is weak it need to be replace or service
to service it you will have to unscrew the washer and adjust the jet back to is position connected to the drum then clean any form of dirt around it
but if you need to get another one apply online on at www.appliancecanada.com/ full of surprises like Washing machine Electric Cooktops · Gas Cooktops. Microwaves ... Sales centres are located in. Toronto and London, Canada.
good luck and thanks for using fixya.
Jun 11, 2010 | Zanussi WJD1257W Front Load Washer
Drum is stuck and does not move after a noiny spin. pls advice.thanks
Sounds like possibly the main drum bearings have seized.
To check, remove the rear panel of washer, remove the drum belt, and try to turn the drum by hand, if it is noisy or rumbling, or not turning at all, then likely the the drum bearings have seized.
This is a major repair, and could be expensive!!!
Mar 17, 2010 | Indesit W 123 Front Load Washer
The door latch has no tension in it and door will not open. the wash finishes completely and no water is left in drum?The latch seems to be broken and I need to open door....how can I do this?
The normal procedure is to remove the top cover, and force the door open from inside by reaching down and pushimg the door latch open with a screw driver or similar.
Feb 05, 2010 | Indesit W 123 Front Load Washer
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
How do I open the drum in an Indesit washing machine
remove back cover. remove heater held in by 1 10mm nut, prize heater out and you can see into the gap between tub and drum and fish object out
Sep 06, 2008 | Indesit WA 125 Front Load Washer
Wd10 indesit washer banging
It could be the drum bearings. If you can move the drum up and down, the bearings is worn. It could also be the balanceweight that sits on the top of the outer tub that have gone loose. It's usually made of cement, or cast iron.
Jan 23, 2008 | Indesit W 123 Front Load Washer
We have a indesit wil 143s faulty
the pressure switch should be easy to replace. it will be a round unit with wires going into it and also a small clear plastic tube attached. it is usually mounted around the top edge of the case. i would also check that the pressure system is not blocked (the other end of that clear plastic tube) as blockages may keep pressure at the switch leaving it in the "full position" pop the pressure tube off of the switch and force some air down the tube to check.tony.
Jun 03, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
949 people viewed this question
Top Washing Machines Experts
