Question about Klein Tools Klein Low-Voltage Tester
Greetings, I have a bp sx120 solar panel and need to know the wiring is for 12 vdc or 24 vdc on back of panel in junction box
  • 308 Answers
Would like to know more about the solar panels discussed and shown on 2nd October 2014 at 05:15+
Solar panels are typically rated at .3 volts per cell. These cells are connected in series until they add up to 12 volts,24 volts or 36 volts depending on the solar system. The more cells you have the higher the charge rate of the batteries connected to the system. The DC voltage from the cells are used to charge the batteries then the voltage from the batteries is used to drive a DC to AC- convertor which is the power used by your home. The more cells connected the quicker it will charge the batteries and the more batteries connected the more power the solar system can provide.
Oct 04, 2014 | Solar 200 Amp Murray Mda 2200 Main Circuit...
Having trouble with Solar charge control. Prostar.30. no light on and appears not to be charging batteries, light has flickered on and off twice, have checked the solar panel, Batteries are holding at...
That's an issue with the inexpensive charge controllers that is known. The internal voltage regulator and pulse width modulator isn't performing correctly and interpreting the power from the panel. I recommend you look at getting an AIMS Power charge controller. Their 30A model is flawless.
Apr 16, 2013 | Morningstar ProStar Charge Controller,...
How many major companies have solar panels?
click in this link
http://en.wikipedia.org/wiki/List_of_photovoltaics_companies
scroll down on page to see manufacturers.
Hope this helps.
Dec 03, 2012 | Computers & Internet
Do you hhave a wireing picture or plan to wire the load center
Here are links that show basic wiring inside a breaker box.
Please look at the images.
If you need more help, answer back and we'll go to the next step
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/240-v-water-heater-circuit.html
http://waterheatertimer.org/Circuit-breakers.html
http://waterheatertimer.org/Color-codewire2.html
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
Breaker size:
15 amp breaker connects to 14 gauge wire
20 amp breaker connects to 12 gauge wire
30 amp breaker connects to 10 gauge wire
Home Depot and Lowes have a breaker and wire size size chart next to wire cutting machine
These stores have guys who know the basic breaker size for your big appliances
Each appliance has a name plate showing wattage and voltage.
The wattage tells you what size wire.
The voltage tells you what size breaker and whether you need a 120V breaker or 240V breaker.
To lay out your home wiring:
The kitchen microwave needs a 20Amp 120V 'dedicated' line that goes just to the microwave.
The rest of the kitchen plugs are served by another 20 amp 120V breaker
When laying out rest of house, figure how much wattage might be used in an area.
For example the den might have a big 500Watt TV, and 2 ceiling fans and 4 lights.
Add up the wattage and decide how many plugs and switches you want on each breaker.
Now let's say you have a 20Amp breaker which can carry 1920 Watts for the den.
Inside the breaker box you have a 12 gauge wire for the 20 Amp breaker.
The 12 gauge wire has a black, white and bare ground.
The black connects to breaker. The white and ground connect to Neutral busbar.
The 12 gauge wire leaves the breaker box and goes to the first box in the den.
This box is your junction box.
The junction box can be a switch box or a ceiling light box.
You cannot have any junction boxes that are covered by drywall.
Junction boxes must be accessible. All boxes must be accessible.
For example, you choose a ceiling box for your junction box.
The junction box is also the same box your ceiling light connect to.
From your junction box, you branch off a wire that goes to next box.
And then a wire branches off next box and goes to next box. And so on.
If you need more help, answer back and we can help.
Oct 24, 2010 | Gb Electrical 100 Amp GE Load Center
There are cut wires and no cord for the second hand dishwasher i purchased and I need to find out what wires I am connecting and where
There should be a small junction box under the dishwasher behind the front toe panel. There should be three wires:
BLACK - HOT (120VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - GROUND
You can purchase a three conductor power cord from any hardware store. A 3-prong power tool power cord works the best, as they have a durable outer sheathing and have good current handling properties.
Simply match the corresponding colors (black to black, white to white) and ground the green wire to the chassis. There should be a ground lug somewhere to connect it to.
Use wire lugs when splicing wires together and use the wire strain relief (if equipped) on the junction box. The strain relief is located at the point where the wire enters the junction box and keeps the wires from inadvertently being pulled.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 29, 2010 | Maytag 24 in. MDB5601AWS Stainless Steel...
Would this work or burn out fans? Amps on one fan is 1.5 and the other is 5 amps I want to run a 12/2 wire from the panel and to the duplex switch and tie it into a 12/3 wire that goes to switch to...
Yes everything would work perfectly. I see no problems in your plan. Even if both fans were run off of one switch they would not burn out, the circuit it appropriately sized. You could even go a step down to save yourself some money and use 14/2 and 14/3 (supposing its only the fans running on the circuit). You can run up to 16 amps on 12 AWG wire and up to 12 amps on 14 AWG wire (80% of breaker tolerance). Also when it get to the fans use a wire junction box run your 3 wire cable in there and branch out to your fans from there with separate 2 wire cables. I believe that was your plan just wanted to clarify. Good luck!!
Jan 02, 2010 | Broan-NuTone Nutone Utility Exhaust Fan...
Power on problem.
What do you mean the power supply has been repaired and outputs 24 vdc and 12 vdc?
Jan 14, 2008 | Protron PLTV-32 Television
Klein Tools Klein Low-Voltage Tester Logo
115 people viewed this question
Top Klein Tools Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Klein Tools Measuring Tool and Sensor Expert? Answer questions, earn points and help others
