Question about Datalogic Heron D130 Handheld Barcode Scanner
Heron D130 Drivers for USB-COM
I have downloaded the drivers from the dalalogic site but i get only the inf files. and when i connect the heron d130 barcode usb reader to my computer(XP is the OS) i am not being prompted for configring the usb-com files,
Can anyone plz help me for configuring the heron d130 reader and USB-COM drivers so that i can read the scanned data from the virtual serial port
2 Suggested Answers
Noggin
  • 944 Answers
SOURCE: Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Posted on Mar 22, 2007
Change drive belt D130
PDF of the manual is here:"http://www.homedepot.com/catalog/pdfimages/fd/fd904936-46bd-471e-9536-7c3ca3698e81.pdf"
Oct 16, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
Do you have a diagram of the parts to fix alignment
Here is a link to the John Deere parts site. Type in D130 in the model box, you will also need your serial number. Hope this helps.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Jan 30, 2016 | John Deere D130 22HP V-Twin Foot Pedal...
We have a Heron DataLogic D130 Bar code scanner for our POS system. We have had them for 3 years with no previous issues until a day and a half ago. I just got a new computer setup with the POS softwa
Possibility is the that the engineers of your POS Software company are right, but we can definitely prove them wrong provided we test and, or check the same POS software or setup on a similar brand new computer.
Sep 05, 2014 | Datalogic Computers & Internet
Config
Quick reference is just for simplified configuration. For detailed configuration go to the reference manual.
Download:
Hopefully you know about Code families and specifications? If not - you can learn it here.
Apr 25, 2013 | Datalogic Heron D130 Handheld Barcode...
Heron's formula
Heron's formula is used to find the area of triangle when the length of all sides is known.
Formula:
Oct 23, 2011 | Texas Instruments TI-84 Plus Calculator
The scanner doesn't read the barcodes anymore and makes a weird noise while we're using it. is there anything I can do to solve the inconvenience immediatly? thanks
We have had the problem, that the scanner generated a crazy sound after it dropped onto the concrete floor. I think the buzzer came loose. Best thing to do on a short time basis is to disable the beep via the manual.
You can find the manual here:
Jan 20, 2011 | Datalogic Heron D130 Handheld Barcode...
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Datalogic Heron D130 Handheld Barcode Scanner Logo
4,374 people viewed this question
Top Datalogic Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Paul Bade
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
