Question about Pool & Spa
My polaris pump cyle remains on reverse--how do I fix this--kIm
  • 128 Answers
Replace the backup valve.
Posted on Aug 30, 2009
Polaris Booster Pump PB4-60 Overheating
see side of motor make sure wiring correct if ok maybe you got a bad one
Aug 29, 2012 | Polaris Pb4 - 60 Booster Pump
How do I reverse a lockout of aux 1 polaris?
check to see if repair man disconnected that aux if so plug back in if not go to system set up to activate that aux
Jul 07, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I am having difficulty removing the impeller on my BaquaPure 2.0 Horse Power pool pump
reverse screw and regular thread on impeller hold back of motor with 9/16 wrench
Jul 06, 2012 | Polaris Pb460 Polaris Booster Pump...
My reverse osmosis system causes my Grunfos pump to cycle on and off for two hours aftr drawing a gallon of water from the reverse osmosis. Is there way to fix this so that the pump doesn-t cyle on an
HI THIER MR.STEELE. MY NAME CANDY A..I COULD TOTALY UNDERSTAND WHEN SAY THAT THE CYCLING OF YOUR PUMP TURNING ON &N OFF CAN GET VERY ANNOYING.LET ME ASK U A QUESTION.? HAS THIS CONSTENT CYCLING CAUSE YOUR POWER BILL TO INCREASE? OK NOW ,LETS SEE WHAT WE CAN DO TO FIX THIS PROBLEM OF YOURS..THE ITEM THAT TELLS YOUR PUMP WHEN TO COME ON. HAS TO HAVE SOME KIND OF SETTINGS ADJUSTMENT.ON IT WHAT U HAVE TO DO IS.SPREAD 4 IT TOO COME ON WHEN U WANT IT TOO.
Dec 23, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
Polaris vac doesnt reverse . which way is it supposd to be running, watr fow away from vac or towards vac?
When these pool cleaners are not reversing, there are several things that you need to check.
  1. Make sure that the back up valve is cycling (it should move in multiple directions).
  2. Check the wheel RPM and make sure that it is between 28-32.
  3. Make sure that the debris bag is empty.
  4. Check to see if the head float has water in it. If it does, replace it.
  5. Make sure that the feed hose is floating.
May 24, 2010 | Polaris 280 In - Ground Pool Cleaner with...
Water remains in the washer after the cyle is
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
Polaris 340 pool cleaner, will not reverse
A big problem with this cleaner is that the screws come loose with vibration. You'll have to disassemble the cleaner to get to the power module, once you have to power module out, remove the endcap and check the screws on the cams that engage the reverse drive mechanisms. The main problem is when the screws come loose, they won't fully engage the reverse drives and will sometimes cause the cleaner to stop while it should be reversing, then continue on forward mode. I guess the best advice I have is to make sure all the screws are tight, but not over-tight as you can pull the threaded inserts out of the plastic. 1dcd685.gif
Sep 17, 2009 | Polaris ATV
I am wondering in what position should the reverse thruster be positioned on the polaris 380. Should the water exit port be facing up or down?
You will have some serious problems if you don't put the reverse thruster in the correct position. Be sure to read the instructions carefully. Look at the pictures closely if there are any. Get a magnifying glass to see the detail and position of the part. If not call the toll free number of the manufacturer and ask them exactly what you need to know.
Jun 10, 2009 | Polaris 380 Automatic Pool Cleaner with...
Pool & Spa Logo
69 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
