Question about Refrigerators
Top refrigerator not cooling--freezer icy
My Amana BB20 hasn't been cooling on the refrigerator side, though the freezer is plenty cold. The freezer gets very icy within a day or so of my cleaning it out. When I unplug the unit to let the ice melt, it helps the refrigerator for a little while, but the last time I did it, it wasn't even a day before the refrigerator stopped getting the cool air it needed.
  • 24 Answers
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Posted on Jul 28, 2009
Upper fridge not cooling, freezer still icy cold.
check fan should be run in freezer,no blockage should be in its air flow by ice or any other item
Jun 18, 2014 | Amana ABC2037DTB / ABC2037DTQ Bottom...
I have an Amana Temp Assure refrigerator (model# on panel BB20 or BRF20) The fridge is not cooling. The freezer appears to be working but here is extra frost in the freezer - mostly on the right side. If I...
I would check the evaporator fan and make sure that is is turning to blow the cold air from the freezer section to the refrigerator section. With bottom mount freezer, that fan is very important since cold air drops.
If the fan is operational then you need to check out the defrost circuit (defrost heater, defrost thermostant, defrost timer) and make sure that is operating. If you take off the back panel (interior) of the freezer, and see a lot of ice build up then you will need to defrost the unit (a hair dryer will speed up the process) and then troubleshoot the defrost circuit and order the parts you will need to fix it. Once defrosted, the unit should work for a several days to a couple of weeks before the ice buildup affects the unit again, which will give you time to receive the parts you need.
NOTE: When you defrost the unit make sure you are ready to deal with all the water. Either spongs and a bucket or a wet/dry vacuum.
Jul 14, 2011 | Refrigerators
The top two shelves of the Freezer and Refrigerator are not freezing/cooling!
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The top of fridge and freezer isn't cooling bottom is
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 06, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Items in freezer on top level have frost on them. It is appearing on top right side (as you face freezer). Long, "furry" frost has formed.
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 28, 2010 | Amana ARB1914C Bottom Freezer Refrigerator
The top portion of both the freezer and fridge are warm but bottom half are freezing.
heatman101
Nov 27, 2010 | Amana ARSE66MB Side by Side Refrigerator
Have a amana with bottom freezer. Everything
Keep in mind, your fridge 100% depends on the freezer. You have a defrost system problem most likely(see if icying up in the back wall of freezer). And if so, most likely defrost thermostat went bad.
Amana refrigerator repair orange county, ca
Feb 06, 2010 | Refrigerators
Amana SCD25tw side by side. Ice cream very soft, freezer blows semi cold air NOT ice cold. refigerator side seemes ok. I checked coil and it is NOT icy.
If the coil is not iced up then it is not a defrost problem but rather if the coils are not completely cold all over then the compressor is failing or the refrigerant has leaked out.
Sep 05, 2009 | GE GTS22KBP Top Freezer Refrigerator
1999 Amana BB20/BRS20 refrigerator not cooling
Take the back cardboard panel off of the back and feel if the compressor is hot. alsocheck to see if the condensor fan is running. if the fan is inop, change it. If the compressor is hot, find a clamp on amp probe and clamp it on one of the wires going to the compressor.If the reading is over 5, you have a bad compressor. You may be able to get by with a RCO410 three in one hardstart.
Dec 08, 2007 | Refrigerators
Refrigerators Logo
533 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
