Question about Cameras
I have an australian version of the canon digital ixus 70 camera and the bustards wont fix it cause they say it has sand in it ??they choose the easy way out this is still under waranty. Anyway the camera wont turn on on a fully charged battery the camera is just dead i cant see what sand has to do with it??? .after they take your money they dont want to know you???buy the way i am from australia any advise would be very thankfull bye
    Brigadier General:
  • 4,090 Answers
Ok try this, maybe they've got tired of taking easy money of $90 for the fix
This is not a joke........
Use a can of compressed air and blow around the lens while it is extended. Even if the lens wont extend still use the compresses air on ther lrns area.
Take a relatively firm approach with this problem slap the camera into your palm two or three times.
Not lens down in thi case of an extended lens, but using the side or rear of the camera to make contact with your palm
Make sure you have the camera cord around your wrist so as not to lose it across the room.
Do this several times and turn it on and off till the message of turn on and off no longer shows(if it ever did) and the lens retracts or extends when turned on and it works correctly. The compressed air will help remove any accumulated dust that is jambing the lens.
This is a tech fix and not a joke, they charge you $90 to do this and this fault is not uncommon in many of these small cameras
dust and dirt get taken into the lens bay and eventually cause it to stick. Hence the use of compressed air with the brutal approach.
you can even take it to a mechanic shop and use their air gun blower attachment as it has more pressure than the aerosol can.
good luck
Posted on Jul 28, 2009
Am trying to get a manual for canon digital camera IXUS 70 to see the seetings of the camera and the funtions of each button
Here is what you need.
manual for canon IXUS 70
* choose from 4 available manuals and follow download instructions.
If you want visual instructions, you can watch how it works from this video
instructional video for Canon IXUS 70
All I want in return is for you to rate this help. A 4 thumbs up is much appreciated.
Thank you for using Fixya.
Sep 08, 2010 | Cameras
How to fix digital camera canon ixus 70 'lens error restart camera'?
Would not recommend opening the camera as the chances are much greater for you causing greater damage. BUT would instead recommend that you try the seven sequential repair step outlined for a lens error in the below listed Related Link "Fixing a Lens Error on a Digital Camera". None of the steps outlined in this link involve opening the camera. and reportedly you should have close to a 50% chance of success with these techniques.
If you cannot repair the lens yourself with the first related link, then consider trying the two 'Digital camera repair" links below for two online digital camera repair businesses.
Sep 02, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lost instruction manual
Easy fix. Just go online to the usa canon.com site and look for the downloads in the consumer product section... You can get a digital copy of the entire manual there.
May 15, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My canon ixus 70 camera is not responding at all!
Just check that the SD card is inserted...camera wont power up if there is not a card present.
Mar 14, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Error, Restart Camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera lens will not open
Oct 12, 2008 | Canon IXUS V2 Digital Camera
Canon digital ixus 70 pdf manual
My Canon Ixus 70 will not switch on although the battery seems fully charged have you a solution please or does anyone have similar problems and their possible solutions thanks,
Bazzeruk
Jun 23, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens wont close
tryig to force it closed if sand is in it will do further damage. Can you gently extend the lens and jiggle it to see if any sand comes out. Most likely this fault needs repairing to open it up and remove the sand.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
77 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
