Question about Ovens
Beko oven door - permanently detached?!
I had to take off my Beko oven door in order to get a washing machine past it in a narrow galley kitchen ... unfortunately I had no idea that the 3 screws at the top and the 3 screws at the bottom were actually screwed into metal plates BEHIND the facia, and these plates are no longer aligned with the visible holes. Any advice? I've been 3 weeks without an oven and am craving pizza! :-(
  • ecoten11 Jan 18, 2011
    I've got the same problem. Any help appreciated.
  • Anonymous Mar 14, 2014
    Hi. I just replaced the front door of my Beko oven after the GF smashed it, and the plate that the screws to secure the top hinge go into (which sits behind the metal fronting/base plate) has slipped down and it is impossible to fit the hinge back on now. I have unscrewed tried to prise the fronting/base plate off as it seems as if it should just come off easily and then I would be able to just reattach the hinge to its securing plate whilst off and then screw the lot back in but it is stuck almost as if it is welded to the other inner plates due to grease getting in the gaps and then hardening like glue perhaps. I have tried using a flat head screwdriver to knock the base plate free of the internal plates but no luck as of yet. Please help my GF is about to get unhappy I feel!!! PS It's a BEKO DG582 WP. Thanks in advance
Hi - in the end I found the cheapest local oven repairers and they ended up having to do a bodge job ... they admitted that Beko was a bad brand with lots of design problems, this being just one of them. By disconnecting and opening up the back he managed to get one of the hinges back on (with my help!), but for the other he had to resort to using bigger screws coming in from the front. Recently, after less than 18 months of use, the oven and one of the hotplates stopped working on the same night. I gave the whole thing up as a bad bet and ordered a more expensive Indesit I'm now completely happy with. I think with ovens you get what you pay for. I would never touch another Beko ANYTHING with a barge pole!
Posted on Jan 18, 2011
  • sairzie65 Jan 19, 2011
    Just to be clear ... sairzie65 is the same as sairhug ... I couldn't get my email/password to work so re-registered. Yes, I'm jinxed!
  • ecoten11 Jan 19, 2011
    Thanks very much for that. Very good to know.
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
How do I clean beko oven door inside panel?
Oven door glass is a "sealed" unit that accumulates stains over a period of use. It is not intended to be removed, unsealed, cleaned, resealed, and reinstalled.
Dec 28, 2013 | Ovens
I have a Beko Electric Cooker, The oven is making intermittent rattling noises, which i think is the fan? How easy is it solve.
some models are acsessed inside the oven if you open the door and can see screws at the rear of the oven youre in luck otherwise it remove the rear cover of the oven and do it from there
Nov 13, 2013 | Ovens
My beko oven is leaking steam from underneath. What could the problem be.
There is no solution it's a design fault with the lower oven seal not being fixed all the way round. Beko will fob you off telling you to tip the oven back this won't work either my landlord has had buy us a new oven due to it being a cheap oven and beko washing there hands of it and not wanting admit faulty products
Jul 05, 2011 | Ovens
Oven door lock pin broke
how did you fix it?? i have the same problem!! :(
May 12, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Loose beko oven door ??
CHECK FOR A SLOT WHERE THE HINGE GOES INTO IT MABE YOU CANT SEE IT BECAUSE IT MIGHT BE CLOGED WITH FAT CLEAN WITH SOAPY WATER AND FIT THE PIN INTO THE SLOT AND IT SHOULD BE FIXED,
Nov 29, 2009 | Ovens
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Beko SC152 oven door will not close properly, couple of mm gap at the top and heat is escaping, please help regards adele
your door hinges are probably worn,theyre under spring tension.
go to your local appliance repair shop with the model number and they can order you some,or arrange to do them.
hope this helps.
Mar 23, 2009 | Ovens
Door hinge of oven detached on one side
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached.
very simple once i discovered levers on the hinges.
Dec 19, 2008 | Ovens
Ovens Logo
588 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
