Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
The screen comes on but is dim - Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
    Guru:
  • 1,894 Answers
Just reset the video settings to default.
this will get solved. else get back to us
Posted on Jul 28, 2009
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Screen doesn't want to come on, then goes dim
The problem is caused by one of the inverter transformers, or one of the backlights behind the LCD screen is going.
Jun 02, 2012 | LG 22" FLATRON LCD Monitor
Dim screen
Its going to be either the lcd or the inverter more then likely. Go ahead and unhook the lcd cable from the motherboard and the back of the LCD. Reseat the cable into the LCD and the motherboard. If its still dim then the best thing to do is to replace the LCD cause it comes with the inverter.
Apr 28, 2010 | Dell Latitude D800 Notebook
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
The screen is dim and goes black everytime i touch the wheel
Here is the link to the user manual - in the Settings Menu, there is a way to change the frequency with which it dims:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
Mar 24, 2009 | SanDisk Sansa e200 MP3 Player
The screen comes on fine but then dims????
Hi there, I have the same monitor, but mine has a broken screen. It's probably the inverter chip, that makes your contrast bright.
Jan 03, 2009 | Westinghouse L2410NM 24 in. LCD TV
Screen troubles
I assume you are running it under normal power supply (mains)?
Try checking your display settings, they may be set st a lower brightness level. As you switch on the computer it is taking a few seconds to catch up and dim down once the settings kick in.
Aug 26, 2008 | Compaq Presario R3000 Notebook
Power Brightness dims after using Kinoma Player
Ok i think i can help,
Step 1: Go to preferences
Step 2: Go to power
Step 3: Change the Auto-off after: feature and increase it to 3 minutes, the maximum.
I know this will only help it a lil from the 1 minute you had before, but if you pres the volume button or something within the 3 minutes it will restart the 3 minutes.
Masalama
Sheeraz Khan
Jan 02, 2008 | Palm Treo 755p Smartphone
Treo 650 screen brightness
Try Pressing the Option button and then P to bring up the Adjust Brightness control enabling you to dim or brighten the screen.
Dec 29, 2007 | Palm Treo 650 Handheld
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
89 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
