Question about Sony Playstation 3 (PS3) Console
Playstation 3 i have the dns but i need every thing else like the default router and i put the dns in i test connection it says ip address obtained but internet connection failed it says dns failure i need internet connection ive been trieng forever
The DNS should be informed by your internet service, but most times the system recognises the DNS by looking for it on the router .
it's happening to you because the IP is got from the router (and it'll be always correct), but the DNS ,that allows you to connect to your internet service must not be correct .
try using the default automatic settings when asked, the ps3 system will try to find the DNS and everything else necessary for your internet connection .
Posted on Jul 28, 2009
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
To specify DNS server address settings, do one of the following:
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
Ip address
change its setting from atomatic to mamula and then via using you computer go to RUN type CMD and then there type Ping you will get IP address from here then paste it on Ps3 internet setting..
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
Need Help With COnnection 2 PS3
call sony the #should be in your white manual, you may need to call your router company to open up certian ports, when you talk to someone at sony they will give you the port #s you need to open.
May 02, 2009 | Sony Playstation 3 (PS3) Console
Connecting PSP to wifi
Change the primary DNS of your PSP to 4.2.2.1 and secondary dns to 4.2.2.2
Apr 25, 2009 | Linksys WRH54G Wireless Router
Getting on line
If you are connecting through your wireless router, you should just let it auto obtain an ip address and auto obtain dns. Is DHCP on in your wireless router?
DNS is the ip address of a server that resolves names like www.something into an ip address. Your ISP usually gives you these numbers.
dns=domain name system
Dec 01, 2008 | Nintendo Wii Console
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Nov 17, 2008 | Dynex 4-Port Ethernet Broadband Router...
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
HELP MEEEEEEEEEEEEEEEEE
192.168.0.1 or http://192.168.0.1/index.php
this is your modems default web page
default username is admin/Admin
default password is password/Password
this should work for all routers if this dose not work put your routers ip in the top bar no www. needed
Jul 07, 2008 | Sony Playstation 3 (PS3) Console
My wii wont connect to the internet it found the box and i put the password in but it will not connect it also wont pass the conection test
1. Make sure you're connected to the internet via something other than the AirPort card (i.e. Ethernet). Also, make sure AirPort is on.
2. Turn on Internet Sharing:
* Go to System Preferences, click on the Sharing icon, then click on the Internet tab.
* Change the Share your connection from: pop-up to 'Built-in Ethernet.'
* Under the To computers using section, check the AirPort box.
* Click Airport options...
* Enter an easy name such as wii. Leave all the security options blank -- implementing security is an exercise left to the reader -- then click OK.
* Click Start in the Internet Sharing panel.
3. Gather Information:
* Open Terminal.app and type ifconfig en1. In the output...
* Look for: inet xxx.xxx.xxx.xxx netmask ...
* Take note the IP Address associated with the first inet, negating values after the # (mine was 10.0.2.1; yours may be different).
* Type dig. Near the bottom of this output will be SERVER: followed by an IP address. This will be the DNS server you will use for your wii.
4. Configure the wii:
* Select a connection to edit.
* Choose Manual Setup.
* Enter the following parameters:
* SSID: wii (or whatever you chose in step one)
* Auto-obtain IP Address: No
* IP Address: Take the first IP Address you obtained earlier, and make the last digit different. i.e., mine could be 10.0.2.4 (10.0.2.1 was original)
* Subnet mask: 255.255.255.0
* Default router: The original IP Address, unchanged. (10.0.2.1)
* Auto-obtain DNS: No
* Primary DNS: your DNS SERVER from the dig output.
* Secondary DNS: leave as 000.000.000.000
* Test your connection at the top of the screen. hope it works
Jul 06, 2008 | Nintendo Wii Console
Sony Playstation 3 (PS3) Console Logo
123 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
