Question about AOC LM742 17" LCD Monitor
OSD locked in AOC LM725
I vahe locked OSD menu in AOC LM725.
SOURCE: Unlocking of OSD in AOC LM725 Monitor
For my 917Sw 19"w, I just ran into this problem. It was kinda annoying, but after looking around then remembering to look in the instructions, I found I just had to turn off the monitor, then hold the left button as I turned the monitor back on.
Posted on Oct 10, 2008
SOURCE: OSD Lock
  • OSD Lock Function: To lock the OSD, press and hold the Left button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the Left button while the monitor is off and then press power button to turn the monitor on.
Posted on Feb 05, 2009
  • 225 Answers
SOURCE: locked osd
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
Posted on May 23, 2009
  • 86 Answers
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: MY MONITOR AOC LM725 GOES ON & OFF REPETEADLY
No, all you need to do is reset the monitor to factory settings. I fixed mine that way.
If your monitor goes off every 3 seconds (like mine did) you have to be fast or siwtch it on/off few times between the steps to get it fixed.
- 1st. unlock the OSD if when you press 'menu' you get the message 'OSD Locked'. To do this switch off the monitor, and press 'menu' while you switch it on again.
- 2nd. Switch it on, press 'menu' and quickly 'press '<' (left) twice and 'menu' twice to get it reset.
- 3rd switch it off and on again and if still goes off after 3/4 secs, try to reset it again.
I reset mine and it is working find. Before it went blank after 3 secs.
I just tried this because I did not understand why if it was a hardware problem I could see the screen for 2/3 seconds and if pressed on/off it came back, it made no sense as a hardware problem.
Posted on Dec 10, 2009
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
Aoc e2043 osd locked.How do I unlock? Lt button trick didn't work.
Aug 25, 2012 | AOC LM742 17" LCD Monitor
Osd Lock how to open?
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
http://s807.photobucket.com/home/budm/allalbums
Jun 14, 2011 | AOC 917Sw 19" LCD Monitor
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
I get OSD locked and cannot change the screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock is displayed. If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
Jan 26, 2011 | AOC Monitor
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
AOC LCD MONITER OSD LOCK
Apr 24, 2010 | AOC 917Sw 19" LCD Monitor
MY MONITOR AOC LM725 GOES ON & OFF REPETEADLY ?
Dec 03, 2009 | AOC LM729 17" LCD Monitor
Locked osd
May 21, 2009 | AOC 917Sw 19" LCD Monitor
Solution #1 above fixed my problem. Turn the monitor off, then hold the left button down while turning it on again. Works like a charm!
Nov 29, 2007 | AOC LM742 17" LCD Monitor
AOC LM742 17" LCD Monitor Logo
325 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
