Question about HP Compaq nx9010
PC comes on but won't boot
I was watching a movie I had on memory, it hung- I was unable to shutdown properly, so I turned it off manually. Ever since then if I start it, it comes on but won't boot. And if I press the F2 button it requests
a pin to be entered. Pressed F11 and F12 but no response. If you guys could be of assistance, I'd be very thankful to you.
My name is ALABI, Phone number: 0092347029758354.
Thanx
  • aba_alao Jul 28, 2009
    No, the hard disk does not boot. It does not show anything.
    Guru:
  • 1,894 Answers
Why are you trying to go into bios? does the hard disk boot? or it shows some error from operating system?
Posted on Jul 28, 2009
    Novelist:
  • 182 Answers
Clear CMOS settings
Remove the RAM and attempt booting.
Add the RAM back 1 module at a time and attempt booting.
Remove any PCI add-on cards
Try disconnecting the second hard drive and attempt to boot.
Test the graphics card in another PC.
Posted on Aug 18, 2011
Phone shutdown
Try fully charging your device before watching a movie.
if that still doesn't work, perhaps the Video Player software is having some technical problems and cannot play the video. try using a different video playing software.
Feb 25, 2013 | Nokia 5630 XpressMusic Smartphone
Turn on only orange lihgt but won't boot up
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jun 12, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
Launch start up repair
Im not sure if you are wanting to get to start-up repair or trying to get rid of it
If you want to access it, Boot system and do a hard nshut down. Restart, you will have the option to Launch start up repair or to start windows normally
If you are getting the option screen unwanted, this is primarily due to improper shutdown.
Whenever you shut down always try to use shutdown, restart options in taskbar.
If in the event you are stuck and need to do a hard shutdown try pressing Ctrl/Alt/del simultaneously
to access task manager.
Here you can end processes hung up or do a proper shutdown
Jun 22, 2011 | Toshiba Satellite Pro L300 Notebook
Compaq presario 2594 us laptop , after boot-up get message ( operating system not found) tried recovery disc, will not formate hdd , will get this message in windows set-up , SET-UP...
I've gist had the same problem after flashing bios ...
go to BIOS and change the SATA mode to IDE. it worked for me.
original instructions:
also You have to turn OFF (disable) the boot from network. The error your seeing is result of the network boot rom not finding PXE server to boot from. Again, be sure to disable boot from network.
PLUS it seems if only 128 MB is showing as memory then the memory sticks might be damaged and not able to retain information/data to complete the installation process. Best take them out clean it properly & replace & try again. Nothing to do with BIOS!
Jun 11, 2011 | Compaq Presario 2594us Notebook PC...
I have a Acer 5517 64bit windows 7 laptop. Just recently I updated my memory cards from two gig to four gig. Now the laptop will not shut down properly. I replaced the old memory cards, and it's still...
Try UPDATING the BIOS firmware first by going on the Acer web site, go to support than download than enter the laptop model...
Download the corresponding BIOS firmware (if they have an .ISO file) than burn it to a CD using NERO so that the CD is BOOTABLE, than BOOT with the CD and fallow the instructions
Hope this helped!
Feb 20, 2011 | Acer Aspire One PC Notebook
Pc turns on when i plug it in but won t boot and won t turn off
Reset the CMOS to defaults. Since it is not actually booting properly you will have to jumper it. Hopefully you have the manual and you need to look at the layout and find what jumpers need to be shorted to reset
Nov 24, 2008 | Intel Desktop Board D850EMV2 Motherboard
My computer crashes now and then... Tends to happen alot when im playing a pc game? It makes this loud screeching noise when it freezes i am forced to shutdown manually
Your Memory card is the problem.
Try this steps:
1. Remove added memory
If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
2. Open computer and reseat memory
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
3. Swap memory location
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
4.Try another computers memory
If you have access to another computer that uses the same type of memory try using its known good memory in your computer. If another computers memory works you know that you have bad memory. If another computers memory does not work and it is compatible with your computer unfortunately your motherboard and/or the slots on the motherboard are defective causing it to be unable to properly read the memory, which means the motherboard will have to be replaced.
Aug 25, 2008 | Computers & Internet
Wont boot up
Could be bad memory, try and get into the bios and turn off the quick boot feature, this will run more complete tests. Also try booting using KNoppix or Ubuntu, make sure u set to boot from a CD in the BIOS. If Ubuntu or knoppix boot's you'll know it's the Hard disk, if they don't, it may be the RAM,
May 08, 2008 | Sony VAIO PCV-W510G PC Desktop
LAPTOP DVD DRIVE WONT PLAY DVDS
ok " get a CD/ DVD cleaning disk , you pop that in and it will clean the lens inside, and they don't cost much, but do so much
good. happy movie watching
Jan 22, 2008 | Acer Aspire 5610-4648 Notebook
HP Compaq nx9010 Logo
169 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
