Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore elite top loader washer
In the middle of one of the washing cycles the machine stopped and I got a message saying "LD" I looked it up in the machine's manual and it says that the drain hose might be clogged. We checked it but that's not the problem. The machine won't even shut off. We had to unplug it for it to go off. Any ideas as to what else might be the problem before we call a repair guy and they charge us an arm and a leg to fix it.. Thanks.
  • sep1094 Nov 23, 2007
    Thanks! We actually checked and there was a nail stuck in there. Saved ourselves over $200. Great site!
  • Anonymous Dec 29, 2007
    Please help, my kenmore elite oasis top loading washer won't drain. It goes to the spin cycle, but then won't spin or drain. I read on here, that if i open the back panel , I should be able to check the hoses for clogs. I have the back panel open, but I have no idea how to check the hoses.
I pressed buttons, restarted it and it just beeps. I unplugged and restarted only to get the "LD" and stops with a beep and water still in the drum.
SOLUTION: Take the large metal backing off. At the bottom of the plastic drum near the left, is a small black rubber "L" shaped tube where the water drains. GET A BUCKET AND SOME TOWELS or you'll flood the room when you disconnect this tube. Use large plyers to take off the clamp. Once you remove it IT WILL DRAIN have bucket ready!! Once the water drains look in the tube and the connectors to the left, you should find your problem. I pulled a piece of rug out from there that was jammed in there and next to the motor causing the problem. Reconnecting this "L" shaped tube was a bit hard but doable. GOOD LUCK
Posted on Aug 31, 2008
  • 248 Answers
Check for something in drain pump.
Posted on Nov 22, 2007
  • Gerald Griffin
    Gerald Griffin Nov 24, 2007
    Glad you were ablr to fix it, good job!!
My washer shows an "ld" code after stopping in the
I have looked and looked and can't find an error code "ID" for any Maytag washing machine! Are you sure that is what is being displayed.
Jun 05, 2011 | Maytag Washing Machines
Why do i get a "ld' signal or a "co" message?
LD = Long Drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display
I don't see an CO error. Here is a complete service manual for your washer. I am sure it will come in handy in the future. Look on page 46 for a list of the error codes.
Regards, Rich
Feb 08, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Stops between rinse and spin cycles giving a ld code..
ld sure sounds like lid switch problems. Suprised to see this so soon, but I did see one come apart on a fairly new Whirlpool. Luckily, it should be easy to check. Unplug the machine first.
Apr 29, 2009 | Washing Machines
Error message
If you tell me the make and model I might be able to talk you trhough it on live chat
Mar 24, 2009 | Washing Machines
Kenmore elite washer problem
LD stands for long drain, you probably have a bad pump or the pump is clogged with lint etc.
Jan 15, 2009 | Kenmore Elite HE4 Electric Dryer
Click on kenmore (below FIXYA)on this website, type in your model number & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, u hv your manual on line.
Feb 09, 2008 | Washing Machines
Ld error message
It most likely means long drain, the drain line could be clogged or kinked. You could also have something jamming the drain pump or a bad drain pump.
Jan 21, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washer stops in middle of cycle,
Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Kenmore Oasis HE 27082 Top Load Washer Logo
267 people viewed this question
Sal De
 Brian Main
Brian Main
