Question about Cell Phones
When sim i insert then the problem arise phone is lock and when i remove sim then sim card absent problem pls give me reply
Insert sim
As far as I know.there are two possibilities to get this error..
1)Sim card not inserted properly:
Try to insert the sim properly..insert it at the desired position
2)Phone may be locked with a particular network:
If the phone is locked with a particular network then you need to unlock it.You can get the unlock service for your Blackberry 9360 Curve from either your network provider or third party unlocking service provider like, unBBlock.com and remove the network lock. Once unlocked it will work with other networks.
3)Sim Problem:
Mostly this won't be in your case because the sim had been working fine with your previous Nokia mobile and also the phone gives the same error message when you insert other sim cards.
4)Hardware Problem:
There might be some loose connection give it to a hardware service shop and check.
May 01, 2013 | Cellet Blackberry T-mobile Curve 9360...
Samsung star II duos GT-C6712 gives the message: SIM card removed.
I suspect that the phone which you are using is SIM locked and hence you are facing such problem. Usually the phones which are SIM locked cannot detect the SIM card other than the SIM card which has been allowed to be used. If any unsupported SIM card is inserted in the phone, such errors will be faced. Therefore I would suggest that you check if the phone is SIM locked or not and then go ahead with different troubleshooting procedure.
Apr 19, 2012 | Samsung star II duos GT-C6712
Sony ericsson j20i insert sim
My sony ericsson j20i mobile showing "insert sim card or to view the demo of this phone first view demo" at first i thought it was simlock by that network after checking with omnius for SE software it shows the phone is not locked by the network
wat does it mean? why its not detectecing pls help me
my mail id is schathuranga87@gmail.com
Feb 13, 2012 | Sony Lands Phones
Hi sir my samsung s8300 emergency calls only after unlocking pls tell me i want soulation pls reply
Hello, sounds like a faulty sim card. Remove sim card and give it a wipe with a dry cloth. Re insert and check, if it still does it you will need to replace it with a new one.Also check your service provider to see if you are still connected. I hope I have helped.
Mar 24, 2011 | Cell Phones
Screen all of a sudden is saying "Check SIM" or "Insert SIM" though no trauma has happened to the phone.
This "Insert Sim"(even though already Sim inserted means) or "Sim Error","Invalid Sim",are all problem arises means that Mobile Locked to Some Network,You need to Unlock it to use other GSM Sim Card,You can Unlock the Motorola KARMA QA1 model using the Unlock code at reliable price at this site
http://www.wickedunlock.com/motorola-karma-qa1/rs11wp9/
Jan 19, 2011 | Motorola Mobility Karma QA1 Cell Phone
Samsung j600 insert sim problem pls....give the solution
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.onlinegsmunlock.com/samsung-j600/rs7wp9/
Jan 11, 2011 | Samsung SGH-J600 Cellular Phone
E71 ON THE CELL CARD ACCEPTED THEN AFTER SAMETIME DISPLAY SHOW INSERT SIM CARD PLS GIVE ME SOLUTION
Hi, could be static on sim card, try taking out and rubbing chip on trousers to remove static, or if you can try your sim card in another phone or try another sim card in your phone
Oct 30, 2010 | Nokia E71 Smartphone
Insert sim card problem in Nokia 6030
nokia6030 mobil is not conecting the network its showing insert sim card
Aug 24, 2009 | Nokia 6030 Cellular Phone
My vodafone SIM card is showing absent in my phone
Kindly switch off your phone take out the sim wait for 3 minutes re-insert your sim Most probably it will be detected. Put your operator selection to manual.
Kindly rate my solution
Jun 29, 2009 | Lands Phones
Nokia 1100
remove sim card
turn it on
press *#06#
it will display a number
give it to me i will give you the code
Apr 30, 2008 | Nokia 1100
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
