Question about Dell Computers & Internet
Audio device not recognized!
Hi, I have a strange problem with my speakers. This morning I switched on my computer as usual and the sound just wouldn't work at all. When I tried going on Control Panel I found "Audio device not recognized". I downloaded a sound driver from the Dell website (my model is an OptiPlex GX110) but that didn't work either. The speakers can still switch on and are still connected to the tower, but the PC doesn't recognise them at all. (They are harman/kardon speakers) It's as if they were never installed. Does this mean that my sound card is irreprabably damaged, will I have to get a new one? Or is there something wrong with my sound driver?
  • kimerciec99 Jul 28, 2009
    Thanks, but I think I know what the problem is - there are no drivers available for Windows XP :/
    Also I did try System Restore but that didn't seem to work either.
    But thanks for your help anyway :)
  • 107 Answers
Please click the link below to download and install the driver again and see whether it works.
http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P03_GX110&os=WW1&osl=en&catid=&impid=
Most times this works!
If not do a system restore to yesterdays date when the sound was working!
All the best!
Posted on Jul 28, 2009
I connected it to proper input and i get no sound. my pc is not recognizing it. i have windows xp.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 24, 2011 | Computers & Internet
Hi. Motherboard DG41RG, sound included. Since this morning I found there is no sound, and going through the usual revision it says there is no sound device. It was all right last night. Where can I begin...
also
hope this helps
Apr 25, 2011 | Intel DG41RQ Motherboard CPU Bundle - ...
Hi i have the Bose companion 5 speakers today there was a power cut in my flat. after that my speakers are not working anymore. the thing is that the led on volume control is on (green) and my pc...
if you are having problems with your sound
also
hope this helps
Mar 30, 2011 | Bose Companion 5 Multimedia Speaker System...
Logitech speakers not working no sound
Turn off the speakers. Restart the computer with the speakers off. Once fully booted turn on the speakers. I had this problem where with the speakers on when the computer was started the sound card was not even recognized. Loading drivers had no affect. Good luck.
Nov 16, 2010 | Logitech Z-10 Computer Speakers
My mms 5650 speakers are for whatever reason not being recognized by my Dell Dimension 8400. I've already made sure my audio drivers are up to date and there are no drivers for these speakers. There is...
Be sure that you have not "muted" your computer's audio-output.
Open the audio "mixer", and check that the "line-out" mix has not been pulled-down to a 'zero' level.
Try the speakers in some other (desktop or laptop) computer.
Try different speakers in your computer.
Check that you're plugging-in to the (green-coloured) "line-out" socket on your audio-adapter (not the blue-coloured "line-in" nor the pink "microphone-in" sockets).
There _are_ limits to what the "Plug-and-Play" features of Windows will detect. Generally, speakers are *NOT* listed within Device Manager.
Try switching from '5.1' to '2-channel-stereo', just to test it.
Jun 28, 2010 | Dell 5650 Computer Speakers
Sound Only through Headphones -ECS A770M-A
Start button>settings>control panel>sounds and audio devices>
Middle tab [audio]
default device, hit the down arrow
and choose the other device
I keep a shortcut on quicklaunch because I switch them all the time.
Jan 09, 2010 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
2.1 SPEAKERS NO SOUND. CONTROL PANEL DOESN'T RECOGNIZE ANY AUDIO DEVICE & CANNOT ADJUST SPEAKER VOLUME.HAVE NEVER HAD SPEAKERS HOOKED UP BEFORE.
That's your problem. It could be:
* the audio-device integrated on your computer's motherboard is "disabled" -- Windows cannot use it
* there is *NO* audio-device integrated on your computer's motherboard -- Windows cannot use non-existent hardware.
* Windows has not installed the correct device-drivers for the integrated audio-device.
* you have an add-in PCI audio-device, and Windows has not installed the correct device-drivers for this hardware.
Do the speakers work if the output from an iPod is connected to the input-jack on the speakers?
Do the speakers work if connected to some other computer (laptop or desktop) ?
Nov 11, 2009 | Insignia 2.1 Speaker System (3-Piece)
I cannot get my speaker to work on my dell dimension 4700. Speakers will work on other computer. Just had the hardrive switched on computer but they said that the speakers were working there. I have tried...
The speaker jack is coloured green on newer computers and usually sits alongside a blue and a pink jack. Firstly, make sure your speakers are plugged into the green socket. If this doesn't solve the problem, you need to check in "device manager to make sure your sound card is installed correctly. Make sure the sound card is listed in "device manager" then make sure there is no yellow dot next to your sound card. If there is a yellow dot next to your device, it's a simple matter of downloading the correct driver for the sound card. If you need further assistance regarding this don't hesitate to ask me.
Best wishes,
Graemevm
Jun 11, 2009 | Dell Dimension 4700 PC Desktop
My computer does not regonize any audio devices
From a distance, it sounds like you do not have the sound card drivers installed. Since it is a SoundBlaster card, go to creative.com and download a utility that finds, indentifies, and then installs the drivers for your sound card. That should fix the problem. If not, then you have other issues going on with motherboard drivers not being installed installed.
Jun 06, 2009 | Audio Players & Recorders
Computer stopped recognizing speakers
This is due to your Drivers for your sound device are unavailable plz make sure that you have installed all your audio devices driver! try to reinstall it! it will help you
Dec 07, 2007 | Polk Audio AMR50 Computer Speakers
Computers & Internet Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
