Question about GE (PSS26MSRSS) Side by Side Refrigerator
My SAMSUNG freeze side working fine but on fridge side is not
The refrigerator side not cold at all,I open inside and found frost build up on the aluminum plate .I manually defrorst it and working fine for 2 to 3 days and same problem again.What's wrong??HELP..HELP..
  • 24 Answers
This has happened in my GE side-by-side (model GSS20IEMDWW). For me,the problem was caused by a faulty temp sensor in the fresh food side.That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Sincethe compressor was running constantly, the evaporator coils (back wallof the freezer compartment) eventually iced over (took about a week).Since the fan that draws air over the evaporator coils could no longermove any air (due to the icing), the temperature in the fresh food sidecontinued to climb. (The fresh food side is chilled through a hole witha motorized door at the top of the dividing wall, so if no air ismoving in the freezer compartment, temps in the fresh food compartmentclimb.)
I replaced the temp sensor in the fresh food side andsolved the problem for a while. About six months later I had the sameproblem again, so I replaced both temp sensors in the freezercompartment - which solved the problem again. (My fridge is about seven years old.)
Ifyou are going to replace any of the temp sensors, replace them allunder the principle of "if one failed, the rest will soon fail too".
Use a website like www.partselect.com to look up a parts diagram for your fridge and see if you can order just the temp sensors. Other websites (www.repairclinic.com and www.appliancepartsworldwide.com) may also be helpful. I have no affiliation with any of the sites I just mentioned - I'm just posting them as resources.
Posted on Jul 28, 2009
Samsung RS267LBSH/XAA evaporators (both the refrigerator and freezer sides) building up with frost. It works fine for about a week after defrosting with blow dryer, and then same problem happens.
Your defrost heaters are not working. The unit takes a week to freeze up and presto - poor cooling. Melt the ice and it works fine again till it freezes up again. Did you check out the defrost timer? Make sure that the defrost elements are not open.
Apr 30, 2017 | Samsung Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Fridge part of product is not working
i have a admiral serial # 1142843us, model # hmg211771. freezer at top freezes. hot at bottom. motor sound like it roars. frost inside frrezer at top.
Apr 09, 2009 | Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
Freezer is cool but not freezing or making ice - fridge not cold
If there is frost on the back wall of the freezer, then the compressor is running. Another (maybe) good thing is the fan is running.
The problem could be -
1) Bad defrost heater
2) Failed defrost sensor
3) Failed defrost timer or refrigerator controller board.
There are diagnostic tests to determine the problem, but require skill at using a multimeter and possibly reading a schematic/wiring diagram.
You can temporarily make the refrigerator run again for awhile by unplugging, opening the doors, and defrosting for 6-8 hours (store food in coolers.). Then plug it back in. Note, water may come out of the freezer as a result of defrosted ice.
Jan 15, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Fridge is not cold enough, freezer is working fine, but has frost
Just had the same problem with my side-by-side.
In my case, the solution was to empty the freezer side, to access a back panel INSIDE the freezer covering the fan and cooling coils. Two screws held the back panel cover on, and when I removed the panel cover I found the cooling coils to be totally iced up, preventing the flow of cold air into the fridge side. I left the freezer open for a few hours until all the ice was melted, before replacing the inside panel. (I used a blow dryer to help speed up the ice melting).
Everything's working fine now for me - good luck with yours!
MW
Nov 17, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirpool side by side refrigerator
The automatic defrost system is malfunctioning causing a frost build up. There are 3 components in the defrost system. A timer, a thermostat, and a heater. The most common to go is the timer. But it would have to be checked by a technician to be sure.
Jul 28, 2008 | Whirlpool Kitchen Ranges
Side by side refrigerator freezing up
inside the fridge there is a cold radiator which has filled with condensation or water from freezing it when say cleaned out the fridge this can be remedied by letting set for a few days outside in the sun so that water can evaporate properly or you can call a repair man and he can pull out frost radiator inside and defrost all the water out by dry wet vac and heater dryer
ice builds apon ice even a little bit can build up to a mountain same thing happended to my top end whirlpool i pulled the metal grate and defrosted this by pouring tap water over the ice which it went down the defrost tube outside water drain this helped greatly havent had trouble with ice since
Apr 21, 2008 | Samsung RS2556 Side by Side Refrigerator
Freezer Working, but Fridge side is not cold.
ou most likely have a defrost problem is there a large build up of frost in the back wall; of the freezer??
Jan 26, 2008 | Frigidaire FRS26KF5C Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
278 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
