FixYa.com
Tags:
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchen Aid Ice maker Stopped working (by 4 users)
posted by msab on Nov 22, 2007
The Ice Maker on our Kitchen Aid Superba Model KSCS251 stopped working. Water is still being dispensed, the ice maker control is turned the on position, I have unplugged the refrigerator and plugged it back in. Freezer temp has been reset to 0 and then it goes back up to 11 degrees. Nothing seems to obstructed in the ice maker. Nothing is frozen over.
Thanks,
Danny Bob
I have an KitchenAid Superba # KSR25IKBT01. My ice maker stopped working but the water is despensing perfect. I turned the temperature up,now i am going to unplug it.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Silent Gl, posted on Mar 03, 2008
Similar problem the ice has frozen in the tray without being dispensed. I have thawed the ice and am waiting to see if the tray will refill and begin operating normally?
Comment by gregorater, posted on Feb 18, 2008
ice maker stopped water still at dispencer, module?
Comment by Guest, posted on Nov 22, 2007
my ice maker stopped making ice ,the water works fine ??????????
Best Solution
Helpful (85)
chris72
Rank:Guru Guru
Rating: 92%, 324 votes
the gear on the head of the icemaker has broken in the center. very common problem. you can replace the ice maker modual to solve the problem
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 05, 2008
Thanks for Trying (70)
BarryisEager
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
Solution #2 posted on May 05, 2008
Use a cup of water and just fill the ice cube maker with enough water for the first batch and the sensor will then begin making ice again.
My ice cube maker stopped working after I changed the filter. After reading countless posts about wiring and defrosting and using a blowdryer into the fill line I emptied my freezer and fridge, then unplugged it. I got no results after two days. I finally just put some water in the ice cube maker (the metal ice cube tray below the white plastic fingers that forms the cubes) plugged it back in and closed the door for a few hours and it worked. I wonder if I needed to defrost the unit at all. It was working before I changed the filter, then the filter was full and stopped water from flowing (or decreased the flow dramatically anyway).
Good Luck
Barry Eager
Solution #3
posted on May 08, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
ice maker does not work
Can you Help with these Refrigerators problems?
KitchenAid Superba Architect KSCS25INSS Side...
KitchenAid Superba 8 years old
My fridge does not cool.... Answer This...
Removing ice maker panel from...
The wires at the bottom of the... Answer This...
Ice-water dispenser
Neither the ice or water... Answer This...
food freezing in refrigerator
My eggs and all produce have... Answer This...
kitchenaid superba side by side...
kitchenaid superba side by side... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
