Question about Palm Treo 750v Smartphone
Setting ringtone i want to change the ring tone from my phone.
  • Anonymous Dec 04, 2007
    how do i change ring tone on treo 750
Here are instructions for setting the ringtone on a Palm Treo 750 running Windows Mobil 6.0 Professional
To change the ringtone do the following:
1.Go to Start and select Settings
2.Select "Sounds and Notifications"
3.Go to the "Notifications" tab listed along the bottom
4.In the Event field either press the middle button or use your stylus to see the drop down menu.
5.From the menu choose whichever option you want to set the ringtone for. i.e. Phone:Known Caller or Phone: Unknown Caller
6. Once you have made your choice go to Ring Type. Here you want to access the drop down menu so you can chose how long the ringtone will sound.
7. Once you have made your choice go to Ring Tone. Access the drop down menu again to cycle through the different types of ringtones. If you have music on your phone you can also choose this as your ringtone instead of having to purchase them but first some steps have to be taken in order for the music to be seen in the drop down menu. I will put that at the bottom of this solution just in case it's needed.
You can use this method to set ringtones for other things such as incoming email, messages and reminders. With Messages Emails, and reminders you can also select music that is already on your phone but I have not been able to do the same with smaller things like "Connection Disconnected".
Here are instructions for making music on your phone into a ringtone.
You may want to have an expansion card for this but it can be done without one. If you are not using an expansion card and would like to make all of the songs on your unit into a ringtone you may have to delete the music files after adding them to your ringtones.
In order to make your music available for choice in ringtone all songs must be in the "My Music" Folder prior to beginning.
Begin by following steps 1. and 2. from above then:
3.Select the "Manage" tab
4.Select Menu then select Add
5. For this part I find using the stylus is simplest. On the top left of the screen push the down arrow found under the words "Select a Sound"
6.From this drop down menu select "My Device" then click on the "Music" Folder
7.Once there Highlight the song you would like to be a ringtone then click "Select"
All done Now the music on you phone is a ringtone. Ringtones made this way can be deleted anytime simply by going into the "Manage" tab again, highlighting the song you wish to delete, Selecting "Menu", Then selecting "Delete"
Posted on May 25, 2008
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
No ringtone
First Option:
You Go to Phone Setting in ringtone setting and check the Ring tone Setting If Ring tone Setting Ok But Not Ringe tone So
Secne Option:
Your Phone Ringer Default So Please change Ringer
And Ringing Problem will Solved Quickly
Aug 15, 2010 | Nokia 1100
I can't figure out how to set a ringtone to my text messaging contact...can u help
To change the ring tone, press Home > Menu, then tap Settings. Tap Sound & display > Phone ringtone. Tap the ring tone you want to use, then tap OK. The ring tone briefly plays when selected.
Also, take a look at these Droid Eris tones: http://www.exectones.com/
May 21, 2010 | HTC Droid Eris by
Where do I change ring tones? I don't want to
Press Menu
go to Settings and tools
then Sound Settings
then Call Sounds
then Call Ringtone
select the one you like.
Other way is on each contact, edit ringtone for that contact.
Dec 04, 2009 | Motorola Mobility RAZR V3xx Cellular Phone
How can i set message ring tone.
Go to menu>my stuff> tools >utilities. Scroll down > my voice.
Then press record .
To set it as your ringtone:
Go to menu, settings, then profiles. Then it takes you to flight mode, silent, vibrate, ring, and etc. On the side it says options. Select it. Scroll down to customize. Then just change the ringtone or scroll down to message tone.
Jul 25, 2009 | Pantech Matrix Cell Phone
Set ringtone as Message tone on Lg Vu
Go to settings to phone to sound and select message tone. (or on those lines). There you will find a list of all the ring tones, including your MP3 collection. Select the ringtone that you have as your ringtone.
Jul 23, 2009 | LG Vu CU920 Cellular Phone
I don't know how to change my text tone on my Samsung z400 there are no Sound options and when I click on the file I want to set as my tone, i click options and there a no options to set it as a...
hi,
To change the ringtone on your mobile phone please follow the instructions below:
Select 'Menu'
Select 'Settings'
Select 'Profiles'
Select the Profile you wish to edit
Select 'Options'
Select 'Edit'
Select 'Voice Call Ringtone or Text Tone'
Highlight required ring tone
Select required ring tone
display_flip('id4570', 'divId4570');
Jun 30, 2008 | Cell Phones
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Palm Treo 750v Smartphone Logo
189 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
