When we came back from vacation and turned on the computer it no longer could "find" our QPS external disk (418115000809 = serial #) . Any ideas how we can recover the data on the disk?
  • 89 Answers
Ya there are some software which can help you in recovering the data such as datarecoverysoft 09
Posted on Jul 28, 2009
My LaCie Rikiki is no longer recognized by Windows Vista or Windows 7 (tried mounting it in different computers) and is either doing beeping or clicking noises, depending on which computer and USB I...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
The piece that allows a usb cord to connect to the actual external hard drive broke off and i no longer can plug it into my computer. how do i get the piece out or fix it?
* the USB cable
* the power-adapter
Or, buy an "empty" external disk-drive enclosure, for about $30, and "transplant" your disk-drive into this enclosure.
Nov 21, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My Western Digital Passport 80GB Hard Drive is no longer detected when I plug it in. The power light is on, the drive is running but it is not detected on either of my computers running Windows...
Any external disk-drive as small as 80GB is probably "out-of-warranty" -- it's likely that the disk-drive inside the enclosure has "died".
You have two options, not mutually exclusive:
* exercise the Western Digital "Customer Loyalty" program -- find the serial-number of your Passport, and access WD's web-site to buy a new Passport, citing the old serial-number to qualify for a significant discount on your purchase;
* open the enclosure, disconnect the disk-drive from the USB-to-disk-drive adapter, buy a new, compatible, disk-drive, and connect it to the USB-to-disk-drive adapter, to "frankenstein" it, creating a "new" external storage-device.
Oct 24, 2010 | Western Digital Passport WDXML800UE...
My qps 525 external cd burner did not come with a driver.
http://www.bioticaindia.com/qps-525.html
try this download..
Feb 25, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
Ive lost my serial number to the sims
Google. =]
Just type in Sims Serial number (or serial code, cd key, SN).
For example:
  • Sims Vacation serial number
  • Sims vacation cd key
  • Sims vacation SN
Just have a look around and you should be able to find a few without a problem. If that doesn't work, I suggest putting "list" within the sentence. That sometimes helps you get different serial codes rather than generators for codes.
For example:
  • Sims Vacation serial number list
  • Sims Vacation cd key list
Hope I was of some help. By the way, which Sims are you trying to get the serial code for? Sims Vacation cd key, will obviously not work if it's Sims 2, and vise versa. So just make sure you search for the specific Sims game you are trying to install.
Feb 02, 2010 | Video Game Consoles & Games
My hard drive doesn't start. I was on vacation for a month, before leaving I unplugged it and now I returned, plugged, but it makes noises, but no lights or info...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
is it an external hard drive? If its not an external hard drive, the same solution still applies because its still about hard disk.
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 07, 2010 | Computers & Internet
Nero won't run on my new laptop. Serial # needed.
Please go below link it's help u, form tht site u will get free and best burning softw..
http://www.filehippo.com/software/dvd/
Thanks for helping u..Good Day
Aug 31, 2009 | QPS Que! USB 2.0 Drive CD-RW Burner
External drive problem
On the computer that is not working, goto:
Right click on My Computer > Click Manage < scroll to Device Manager, then Expland Universal Serial Bus Controllers, then Right Click USB Mass Storage Device and click Uninstall. You will then need to right click on Universal Serial Bus Controllers and Scan for Changes. Plug in the USB drive and it should show up.
Jul 10, 2009 | Hitachi Computers & Internet
External hard drive can not be seen on My Computer
It might still be connected but may need a letter assigned to the drive, go into disk management and if it is there right click it and assign it a letter. If it is not then look at this forum for more ideas
http://www.techsupportforum.com/hardware-support/hard-drive-support/269193-acomdata-external-hd-not-recognized.html
I hope this helps
to get into disk management, go to Control Panel> administrative tools> computer management and will see disk managment in the left menu (for vista)
Jan 10, 2009 | Computers & Internet
QPS Que! Drive change
qps que model 525 will not start. used to work on xp and vista. I think disk is getting full - down to 4 gb left... but problem remains that I cannot start it or open it. Can anyone help?
Thanks.
Feb 15, 2007 | QPS Que! CD-Rewriter CD-RW Burner
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
