Question about Dishwashers
THE glassses inside is where you see it the most like not rinsing right i have looked at the holes on the sprayers cleaned them there is rinse liquid so thats ok but it still has the entire dishwasher has a white film.
  • 11 Answers
We had the same problem and finally found a solution that has worked for us for many years. We found using dry powder detergents didn't work for us. They left a white film and scratched our glasses after years of use. We switched to Cascade All in One Gel and it stopped most of the film. Don't fill up the pre-wash with any detergent, if you have that option, just use the gel in the wash section and you don't need a lot. We fill it up to the lowest line and it cleans REALLY well, or what would be about 3 tablespoons or so. Next we use Jet Dry in the rinse dispenser and set it up to at least medium or 4 or 5 if you have a selection for your rinse dispenser. Next we put 1/2 cup of white vinegar in our dishwasher every time we wash. We pour it in the bottom right before we wash. We have been doing this for 9 years in our old dishwasher and a year in our newer one and have never had any trouble doing this. It leaves our dishes sparkling clean and the glasses aren't scratchy anymore. Make sure any trap down on the bottom of the dishwasher isn't stopped up too and once a month keep those spray holes cleared of any gunk by using a toothpick to clear any holes out of any gunk. Lastly, don't overload the dishwasher and make sure there is space between each dish and position all plates toward the center. Hope this helps. It has made our lives MUCH easier!
Posted on Jul 28, 2009
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
Problem is defiantely your hard water. www.dishwasherfilter.com has a new product out that will solve your problem guaranteed. it is a filter that removes the hard minerals that cause these spots/film before they enter your dishwasher. very affordable and works amazing. they even have a money back guarantee.
Posted on Aug 22, 2009
Dishwasher#WDF120PAPWO Serial #F625003282 Where is rinse liquid inserted?
On the door where you place the dishwasher detergent there should be either a small hole where you squirt the rince liquid or some models have a small door you have to open to get to the hole you squirt the rinse liquid into. Either way it should be located right beside where you place the detergent. I have occasionally seen the insert point being on the top of door, but from the diagrams I saw for your whirlpool it should be next to the soap insertion point. Hope this helps.
Oct 18, 2017 | Dishwashers
Not Rinsing
By cleaning it out, you cleaned the bottom where the water is drawn in and food particles collect, right? Are the sprayer arms working good? The holes on them are not clogged with anything? How does the dishwasher drain? I mean do you have an air gap or does it drain directly into the disposal or sink pipe. Sometimes without an air gap, the disposal will send junk into the drain line if the check valve is not working properly, thus giving you excess food in the dishwasher.
Jan 12, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
Button on sprayer is sticking with no spray
This is typical behavior or sprayers that aren't looked after. Mine typically last 20 years. After use, you need to empty it, wash it, pump the soap through, rinse it, pump the clean water through, empty it and blow air through it. Then leave it open to dry.
Take the wand off, and take everything apart and soak the parts in hot soapy water in your bathtub. Rinse and dry, rub any o-rings with vaseline.
Apr 23, 2016 | Garden
My gilmour wheelpump sprayer just quit spraying. It appears to not be building up pressure. I have cleaned out the valve and screen on the bottom, removed and rinsed out the hollow oval 'ball'...
Your pump cam follower may be broken, such that the pump is just not working. It happened on mine. You don't need to buy any parts. If you open it up and find that the cam follower plastic tabs are broken, Gilmore provides a second set of 2 cam followers on the other side of the cam follower assembly. Just remove some screws, reverse the assembly, and you are back in business.
See photos at:
http://s911.photobucket.com/albums/ac317/vonoretn/Gilmore%20Wheelpump%20sprayer/
May 11, 2011 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
What is the rinse indicator clear knob inside door
That is the compartment for a liquid rinsing agent (Jet Dry). If you use it you can see if the compartment needs to be refilled by looking through the knob. Rinsing agent is supposed to keep glassware from having water spots but is not always necessary.
Jan 17, 2010 | Dishwashers
Bottom Sprayer not spraying. does not look blocked
1)wash arm not spraying(or)rinse not spraying?
wash arm
1)remove the wash arm
2)switch on the machine all blockaged removed automatically.(remove the wash arm).
rinse arm
1)check any scaling in the boiler tank.
2)clean the boiler tank.
3)clean the rinse arm.
Jan 07, 2010 | Dishwashers
My glasses arecoming out with soap and water spots. I think the dishwashing soap has clogged up the washer/ sprayer arms. is there any cleaning solvant (eg CLR) I can use to clean out the washer
add rinse aid to rinse aid dispenser... that should help the spots.. as for cleaning the arms.. not really necessary... but you should pull them off occasionally and see if there is something stuck in the holes... i found rice in mine.
Dec 05, 2009 | Sewing Machines
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Residue inside dishwasher sprayer arms
What it is called is calcium deposits, your water is high in calcium. You may have to clean the part occasionally with CLR or something similar.
You should look into flushing your hot water tank occasionally as well, calcium deposit biuld up after awhile and your water tank has to work extra hard to heat your water, which cost you more money in the long run.
Hope this helps you .
Aug 15, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
I have a hobart dishmachine model# CRS-103
THERE SHOULD BE SOME HOOKS AT THE TOP OF THE MACH INSIDE AT BOTH ENDS AND SOMEWHERE IN THE MIDDLE TO SEPERATE THE WASH TANKS AND THE RINSES TANKS, ALSO AT THE ENDS SO THE WATER DOESNT SHOOT OUT ONTO THE FLOOR,THE SPRAYERS COULD EITHER BE THE WASH ARMS OR THE RINSES JETS IF ITS THE ARMS THEY GO IN THE TOP AND THE BOTTOM ONES GO JUST ABOVE THE WATER LINE OR SCRAP TRYS THE BOTH SHOULD LOCK IN SOMEHOW,I IF ITS THE RINSE JETS THE GO IN THE RINSE ARMS WITCH ARE AT THE EXIT END WHERE THE TRAYS COME OUT, THE JETS SHOULD THREAD INTO THE ARMS WICH HAVE PRE DRILELED HOLES FOR THEM.
Dec 23, 2008 | Dishwashers
Dishwashers Logo
245 people viewed this question
Top Dishwashers Experts
