Question about Sharp XR-32X Projector
Abnormal picture i have give my projector for service techanician was left the wire of fan which adjoining hood lens he was starting projector so many times but result was that projctor went into safe mode and power of ,he was doing several times the result is that projector burn its green filter after that projector shows red and blue images ok when green gun is off, when we started three gun stamounsly we get abnormal picture and we start only green gun than get negitive picture pl. give us solution
  • 2,237 Answers
If it's an xr-32x (as it shows on this pic), it's a dlp projector, not an lcd. therefore no green filter. it has only a colorwheel and a dmd chip to affect the color. if it's not an xr-32x, and it's an lcd projector, replace the green filter. sharp sells the parts for the optical engine. but if it was your service tech that did it, have them replace it.
Posted on Aug 17, 2009
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: abnomal reverse picture
if it was the fault of the technician, they are responsible for the repair. if the green filter is bad, it needs replacing.
Posted on Aug 19, 2009
My PDJ6553w projector turns on, giving me 2 min picture, turns off and the fans goes crazy
sony lcd turns on, giving me signal and picture in 2 minutes, then suddenly turns off and the fans goes crazy. what can I do to prevent this? I have tried to reset the projector and switched the powermode to normal, but this didn't help.
Feb 16, 2013 | Viewsonic Corporation Viewsonic PJD6553w...
SHARP NOTEVISION XG-C50X LCD PROJECTOR: Does this work for laptop presentations as well as DVD projections
Hi there, Sharp makes light and compact projectors with low fan noise. Set the projector up in areas subject to minimal humidity and dust to avoid having to clean the lens too often. Remember that colors will get washed out if the screen is in direct sunlight. Learn a few troubleshooting techniques to get the most out of this work horse projector.
No Pictures, Sound or the Projector Fails to Start
  • If you have no pictures, sound or the projector fails to start, check that the power cord is plugged into the wall and that all the cables are connected to the rear panel. Make sure the remote control batteries are fresh. If you are using a notebook computer, make sure the screen output is correct. Check the Input Mode on the projector. Check the projector physically--is the lamp and cover in place? Check the key lock.
  • Jul 31, 2010 | Sharp Notevision XG-C50X Multimedia...
    I have a screenplay 5000 the projector comes on but shows no picture,also it makes noises coming from the front left side
    if you are behind the projector and it is facing away from you then it could be the lamp blower under the power supply which would be on the right side rear, or one of the 2 fans on the right side. now if you are facing the projector the fan on the right would be the lcd blower fan. you need to make sure your lamp is even lit and then post your problem. this can be done by looking into the lens from the side. a more accurate description of the problem can better help me.
    Jun 20, 2010 | InFocus ScreenPlay 5000 Multimedia...
    Hi we have an infocus 4805 and had to store it (very carefully) for 5 months. Now when we come to use it there is a light for about 30 secs if you look down the lens and then nothing. The bulb had hours of...
    After storage for a while one of the fans may be stuck causing the over heat safety circuit to shut down the projector. Use a bright flashlight & look in vented areas for fans & use a popsicle stick, thin plastic straw or suitable while unplugged (do not use anything metal) & give all the fans you see a little push to turn them around some. Also remove the lamp cover & remove the lamp & push the cooling fan inside the lamp compartment to loosen it up. Put the lamp back in & replace the cover & then plug it back in, wait 5 minutes then try starting it up again.
    Just one of many things that can be wrong but worth a try. Good Luck,
    Jim
    Jan 07, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
    How do i focus the picture
    the lever above the lens will move left to right and vice versa that should focus the picture if not check if the lens itself has a ring around it that is movable to focus
    Aug 15, 2009 | Sharp XG-C55X LCD Projector
    Abnomal reverse picture
    Jul 28, 2009 | Sharp XR-32X Projector
    Optoma DV10 projetor suddenly started made popping sound
    hi,
    Please Check and service the fans and the Air filters. then check again. In case the noise still comes then service the fans or replace accordingly. By complete service of projector, this will work.
    Rave services
    Jan 12, 2009 | Optoma MovieTime DV10 Multimedia Projector
    Short picture time when starting Optoma HD72 projector
    Mine did the same thing. The bulb is used up...replace the bulb. That fixed mine, working great again.
    Oct 05, 2008 | Optoma HD72 Multimedia Projector
    Projector turns off
    hi,
    Please give some more details, Also tell that ur lamp glows or not after fans operates.open the lamp unit and see the condition of inner tube, if that is abnormal then you have to replace lamp again. if it is tuning of and on repeatingly then there is some problem with DMD module.
    Viren
    +91 9814903739
    Nov 27, 2007 | Sharp XR-10X Multimedia Projector
    Sharp XR-32X Projector Logo
    225 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    jasbo
    jasbo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
