Question about HP iPAQ 614 Business Navigator 2.8-tft With Mobile (v6.0) Professional Smartphone
The device has been locked now i need a
The device has been locked now i need a solution to unlock it
How can i flash an android phone which its pattern have forgotten??
Use your android Device Manager And unlock the phone
Unlock your Android device using Android Device Manager (ADM)
As already mentioned, the following method only applies to devices that have Android Device Manager enabled.
  1. On a computer or other mobile phone, visit: google.com/android/devicemanager
  2. Sign in using your Google login details that you also used on your locked phone.
  3. In the ADM interface, select the device you need to unlock (if it isn't already selected).
  4. Select 'Lock'
  5. In the appearing window, enter a temporary password. You don't have to enter a recovery message. Now click 'Lock' again.
  6. If it was successful, you should see a confirmation below the box with the buttons Ring, Lock and Erase.
  7. On your phone you should now see a password field in which you should enter the temporary password. This should unlock your phone.
  8. Now, before you go on with your life, go to your phone's lock screen settings and disable the temporary password.
  9. That's it!
How to bypass Android lock screen pattern PIN or password
Jun 17, 2016 | Android Cell Phones
How to unlock icloud activated iphone 6s
FREE VERSION ENJOY !
Unlock iCloud iPhone 7,iPhone 6S, iPhone 5S, iPhone 6S+, iPhone 7 plus
http://howtounlockicloud.com/
Unlock iCloud iPhone 7, iPhone 6S, iPhone 5S, iPhone 6S+, iPhone 7 plus
All iOS iPhone 4S iPhone 5 iPhone 5S iPhone 6 iPhone 6 plus iPhone 6S iPhone 6S plus iPhone 7 iPhone 7S All iPad's
Remove iCloud activation lock, bypass iCloud lock
First method Free
For using this method to bypass iCloud by yourself you will need:
iTunes installed
Notepad++
Total Commander
iCloudSyncKey software
For decoding the icloud lock you must have a locked iPhone device and a neverlocked device same model only for unlocking time not for your self. With the neverlocked iPhone connect the device to iTunes and make a sync of a picture , melody or any file, after that you dont need any more the neverlocked device. The ideea is that the iTunes needs to be used with the same model like the icloud locked device before bypass iCloud.
First of all after you have all programs ready make sure that the iTunes is not running then open total commander go in iTunes install folder directory look there for iTunesCore.dll and open this file with notepad++. After this search in notepad++ file the "Unactivated" keyword, the search may be repeated if notepad++ does not find the first time the keyword. When the "Unactivated" is found change from "Unactivated" in "Unbctivated" the "a" character to "b". After this operation save the file and close notepad++.
PAID VERSION
Unlock iCloud iPhone 6S, iPhone 5S, iPhone 7, iPhone 6S+, iPhone plus
Download from:
http://unlock-icloud.com
Unlock and remove iCloud for:
All iOS
iPhone 7
iPhone 5S
iPhone 6
iPhone 6 plus
iPhone 6S
iPhone 6S plus
All iPad's
Real and working by software, work on all Apple iPhones
Trusted solution work 100% i recommand it's verified!
The software is easy to use and the support team from unlock-icloud.com offer good technical support with team viewer and video for unlock icloud and iphone repair solutions. The signal work excelent after i have used this software. The software is clean no viruses or other bad things like other software from internet.
With this software i managed to repair my iPhone 6 iCloud errors and bypass activation lock. It's a realy gsm repair tool.
Jan 17, 2016 | Apple iPhone Cell Phones
How to unblock my sim with puk
Unlock SIM card with PUK code
SIM cards lock after three incorrect PIN entries in a row. Your device may display "Enter PUK" if the SIM card locks. To unlock your device's SIM card, you'll need its PIN Unlock Key (PUK) code.
To get the PUK code to unlock your SIM card:
  1. Select the myAT&T tab.
  2. At the top of the page under Wireless, select My Phone / Device.
  3. If needed, click Select and choose the mobile number of the device that needs the PUK code.
  4. Under Support, select the Unlock SIM card using PIN Unlock link.
  5. Use the PUK code and instructions provided on the Unlock SIM Card Using PIN Unlock Key screen to unlock your SIM card.
May 08, 2015 | Cell Phones
How unlock pattern lock on proscan tablet PLT9602G
Hello Heather
You were supposed to remember the pattern you gave it when you locked it. That's why they have the Lock. To keep unauthorised people out.
Give it the right pattern is all I can suggest!
Mar 02, 2015 | Tablets & eReaders
How can I unlock key phone for Nokia 305
There are two ways to unlock.
One is to go to the Nokia center and the other is to format the phone.
If you want to format your cell phone,
You can do by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Jan 08, 2015 | Nokia Asha 305 Unlocked DualbandGSM Cell...
Device is locked
Whether it has phone lock or network lock?? what is your device model?? if its network lock then try to unlock it with unlock codes and try Prounlocking to get unlock code for your mobile and get it unlocked safely..
Dec 02, 2011 | RIM BlackBerry Cell Phones
My yahoo account is locked on my mobile device but isnt locked on my laptop. What do I have to do to unlock my yahoo account on my mobile phone?
i have boost moble lg and my yahoo accoutn is lock how do i unlock it so i can get my email on my phone
Dec 19, 2010 | Cell Phones
PIN CODE
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Jan 14, 2008 | Garmin n vi 680 GPS Receiver
Cant unlock maps
What is the Garmin 510 that can't unlock maps stating exactly? And to Nici07 who said, "Need to unlock device", are you referring to a PIN lock or locked maps?
Dec 10, 2007 | Garmin StreetPilot c510 Deluxe GPS...
HP iPAQ 614 Business Navigator 2.8-tft With Mobile (v6.0) Professional Smartphone Logo
189 people viewed this question
Top HP Cell Phones Experts
D. E. Hev
Andrew Taylor
Andrew Taylor
richie46
Are you a HP Cell Phone Expert? Answer questions, earn points and help others
