Question about Hayward Pro Series 31 Inch In Ground Pool Sand Filter System with Pump
CLOUDY WATER I HAVE CHANGED THE SAND,HAD THE WATER TESTED,ADDED CHEMICALS AND REPLACED THE HOSES.AND STILL MY POOL IS CLOUDY.SO MUCH THAT I CANNOT SEE THE BOTTOM.
    Scholar:
  • 86 Answers
I too have this problem after treatment for algae, especially if I got a day or two without running the pump, it starts to get mildly green. After adding the algaecide, it kills the algae, but leaves what I call the white dead floating...it takes several days for this to phase out.
If you aren't already doing so, put 3" tablets in the pump basket housing, that helps dramatically. Put a pair of knee-high pantyhose (one inside the other), on the return inside the pool. (you will be amazed what it catches after a few days). Also you can try some "clarifier" to help clear up the cloudiness.
I'm no pool expert, but have dealt with the cloudiness myself. Through trial and error, have learned that cloudy water doesn't necessary mean dirty water. It will clear within a day or two if you are keeping stabilizer tablets in pump basket and using shock once a week. And run the pump for about 8-12 hours a day, it will clear up quicker. And to me, using the pantyhose is an extra-filter and it catches the 'gunk' that the sand in the filter isn't catching. (it can't possibly get everything). Be sure to backwash your pump frequently too.
Hope this helps at least some. Good luck!
Posted on Jul 29, 2009
We have a 60ltr tropical fish tank, there are only 6 fish in it at this time, at the moment we have to complete a part water change every week as the water goes green and cloudy.\r\n
we have tried using the algae solution
we use the stress coat solution
we also use the hardness fluid
Posted on Oct 05, 2009
How often should you replace the sand on a SP714TX? my pool water is cloudy
Sand is cheap so replace it if you think that is the problem. i would be looking into water chemistry also. Take your samples of water to a reputable pool shop and let them test it. They will usually do it for free since most likely you will need chemicals to remedy the situation.
Dec 22, 2014 | Hayward SAND FILTER, PRO SERIES
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Pump is blowing cloudy water back into pool
Cloudy water is the bane of sand filters!. I suggest letting filter run day and night. Do not backwash until the pressure rises 8 - 10 pounds above clean starting pressure. Do not try to vacuum or stir up the sediment. when water clears, vacuum to waste. Keep the hose running while vacuuming. A dirty filter is a better filter (up to a point). At a higher pressure the filter will trap more of the fine particles that are clouding your water.
May 28, 2013 | Pentair Meteor Above-ground 22" Sand...
Have saltwater system 6500 gallon pool (18x48) opened pool with 4 bags pool salt, 1 bag stabilizer, 1 bottle algeaguard. Ran pump to dissolve salt first then turned on saltwater system, added algeaguard,...
Thank you for posting your question here on Fixya.com.
You need to be able to test at least chlorine, salinity, ph, alkalinity, and stabilizer. The best way is using test strips. If you have a sample of water tested at a pool supply store that will work too but frequent transportation is more costly than strips. The salinity should be about 3000 ppm, Chlorine should be between 2 and 4 ppm, alkalinity should be between and 80 and 140 ppm and the stabilizer should be between 30 and 50 ppm. Some say up to 100 ppm. Unfortunately higher stabilizer reduces the chlorine's ability to kill algae, etc. When the water becomes cloudy it is likely low on chlorine and is about to turn green. If the test shows low chlorine level then I would add shock to 10 ppm chlorine. If the filter system is working correctly then it should clear up fairly soon. I would not let anyone swim until the chlorine is between 2 and 4 ppm and you can clearly see the pool bottom.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved! Thank you.
Aug 28, 2011 | Intex Pool & Spa
My water is cloudy and says salt level low.....it seems salty enough as I can feel and taste it. Is there chemicals I am supposed to be adding or does this system keep it clean all alone just by adding...
While your problems are likely greater than just the salt content in the water I can tell you that if you feel, or more importantly can taste the salt in the water your salt level is WAY TO HIGH, not low. Have the salt level confirmed with an independent test either at a pool store or using a salt tester.
John
Jul 21, 2011 | Intex Automatic Salt Water System for ...
We have a hayward sand filter model sp 711 13 for our vinyl lined pool. We are having alot of trouble getting the pool to clear up. When we opened it for the season, it cleared up great and was running...
How long is it since the sand in the filter was changed? How long has it been installed? If the water is clean but cloudy, get some kind of flocculant from your pool supplier. Follow the instructions carefully as your pool will need to be bavkwashed on a frequent basis.
Regards alshipman@gmail.com
Jun 27, 2011 | Hayward Pro Series Sand Filter -36" Tank
Water comeing out cloudy and makeing suds in pool
There could be a few things causing these problems. How old is the sand in the filter? Filter sand looses its filtering ability after 3-5 years and needs to be replaced. If the sand needs to be replaced, make sure you get actual pool filter sand. A lot of big box and home improvement stores sell play sand as filter sand. That will cause your pool to stay cloudy and never clear up. If the sand is less that 3-5 years old, you may need to clean it with a liquid filter cleaner that is poured through the skimmer. This works quite well!
Another issue causing the cloudiness and bubbles could be the type of chemicals you are using. I know that shock from big box and home improvement stores cause the water to be cloudy. Algaecides from these stores also cause foaming.
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
I have a 24 ft pool with a sand filter. I use a hayward 1.5 hp pump. I just bought the pool in 2006 and the new filter in 2008. My problem is my pool is always cloudy even after backwashing and adding...
It sounds like your ph is out of whack.
Take some pool water to your local pool store, have them check water quality and ph....most pool store will check for free.
Hope this helps
Jun 20, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
Last fall when I closed my pool, I noticed a fair amount of sand exited out the bottom of the sand filter drain. In previous years, only water drained from this location. I have now opened the pool and am...
You may have to change the sand if you never have. Or if it's not too bad you can "clean" it. When you removed the plug form the pool, there should actually be two parts. This first part threads directly into the filter, and has a screen on it to hold back the sand. The second one is the plug. This is the only part you should remove, except when changing sand etc. Even if the pool filter is working you can have cloudy water. See you pool supply, and try a floc to help settle dissolved solids in your pool. You add this, run the pump awhile to mix, turn pump off overnight, and then vacuum everything next day. Then turn pump back on.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward Pro Series 31 Inch In Ground Pool Sand Filter System with Pump Logo
338 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
